30-31 Model A coupe seat ideas?
Discussion in 'The Hokey Ass Message Board' started by Tman, Sep 23, 2003.
  1. skyspop
    skyspop
    Im using the originals in my 30 plymouth,but I took out some back seats in a corvair,their two piece,with easily workable brackets that i set in my 36 plymouth and they fit perfect.not sure how much wider it is from an A,but they look good.
  2. Donzie
    Donzie
    The middle seat from a Caravan is narrower because it's the one you have to step around to get to the back seat.
  3. mccarrol
    mccarrol
    I used a Dodge mini van middle seat in a 34 Ford pickup. I think it measured 40". It was great. Take off the arm rest and bolt in. I had Fiero seats in originally, but the Dodge was more comfortable. The Model A is likely close to the truck interior dimensions. You may want to cut the frame down to give more leg room, if your tall.
    Joe
  4. Tiggerbear
    Tiggerbear
    I used an old Blue bird bus set had to narrow it but it turned out sweet!!!!
  5. SaltCoupe
    SaltCoupe
    from Indiana
    X2...it's what I'm using.
  6. RFAGrasshopper
    RFAGrasshopper
    I got a middle seat from a Ford areostar just the right size.
  7. el Scotto
    el Scotto
    from Tracy, CA
    Wow.... Seven year old thread back from the dead!! :eek:
    Seeing as it's up, anyone have the correct link to the seat dimension thread?
  8. Canuck
    Canuck
    Mazda MPV van centre seat. Fits great. Provides tilt and recline to back and comes with a adjustable track. Decided to use the track out of a Ford from the 80s as it gave a little more travel with finer adjustments and a slightly lower profile. Upholstery is even a good pattern with a roll around the sides and pleated sections in the seat and back. :D
    Canuck
  9. AntiBling
    AntiBling
    That would be 8 years, but I see you live in California so it's understandable.
  10. theczking
    theczking
    We put a rear seat from a Geo tracker in my sons 30 model A coupe, it fit perfect and leans forward for behind storage
  11. Noland
    Noland
    grand caravan center seat works great
  12. Yea , from post # 5
  13. rustydibris
    rustydibris
    rear bench in a Jeep Cj works well too
  14. Model A Gomez
    Model A Gomez
    I used the middle seat out of a Dodge minivan, it is narrow so you can get to the rear seat, fits in my 30 like it was made for it, had to build mounting .
  15. el Scotto
    el Scotto
    from Tracy, CA
    Doh!! You are correct!! :D
    Does the link work for you? It doesn't for me! :)
    Maybe it's my wack Cali edjucashun.... :D
  16. uglyjesus
    uglyjesus
    from Ohio
    I used a school bus seat.
  17. Nope, sounds like it might be useful, there's so much of the HAMB that has disappeared.
  18. Hitchhiker
    Hitchhiker
    Here it is.
    JUNKYARD SEAT LIST
    '87-'89 Ford ****** rear seat
    Seat back width = 42"
    Seat bottom width = 42"
    Seat back thickness = 3.5"
    (seat back folds forward)
    '90 Dodge Caravan, middle seat?
    Seat back width = 44.5"
    Seat bottom width = 44.5"
    Seat back thickness = 4.5"
    '80s Isuzu Trooper
    Seat back width = 48"
    Seat bottom width = 48"
    '84 Ford Ranger
    Seat back width = 49"
    Seat bottom width = 49"
    '84 Toyota van middle seat
    Seat back width = 34"
    Seat bottom width = 36"
    '91 Ford Festiva
    Seat back width = 38"
    Seat bottom width = 48" (odd shape is fitted to wheel wells)
    '89 Ford Aerostar middle seat
    Seat back width = 39"
    Seat bottom width = 46" (odd shape)
    '91 Chevy S10 pickup bench seat
    Seat back width = 5.5"
    Seat bottom width = 49.75"
    Seat bottom thickness = 6"
    The seat would bolt to a flat floor, with the frame the bottom cushon at highest point looks to be 9.5" high. Bottom cushon has two holes for seatbelts to p*** through.
    OK - Wrangler stuff (pretty small - maybe good for Model A)
    Seat Back Width - 32.5"
    Seat Back Height - 15.5" (from hinge)
    Seat Back Thickness - 5"
    Seat Bottom Width - 33.5"
    Seat Bottom Thickness - 5" (at bolster)
    Seat Bottom Depth - 15.5" (front to back)
    Found one that mounts to the floor in a severely channeled 26-27 T ....90's Isuzu Amigo back seat.
    SEAT BACK 39"x21"x3"
    SEAT BOTTOM 39"x20.5"x8"
    Seat folds forward and the "folded seat" folds forward again!
    85-6 Dodge Colt Vista van rear (3rd) seat.
    38 inches wide-21 inches deep.
    integral retractable belts (center)
    earlier ones don't have headrests
    thin cushions and backrests
    I used modified 80's Chev PU seat tracks on this one
    splitback reclines and folds on cushion
  19. OoltewahSpeedShop
    OoltewahSpeedShop
    I'm on the junkyard hunt for a decent fitting seat for my '29 Coupe. That list will be a big help. Any other ideas?
    Kevin
  20. brett4christ
    brett4christ
    I got both rear bench seats out of a 90 Mazda APV mini van. Middle seat fits mt Model A just fine, and the rear bench seat fits my 46 Chevy truck great. No, the blue is NOT staying! :D
    Just about walked right by it at the local pull-a-part.
    Sent from my DROID device using the TJJ mobile app
  21. mramc1
    mramc1
    I used the middle seat out of a 1999 Dodge Caravan with the slider doors on both sides. The seat fit my '31 coupe perfectly.
  22. I used a seat out of a plymouth voyager
  23. silent rick
    silent rick
    so with this ancient thread, how are all those mini-van seats holding up? i hear that since they're designed for a couple of six year olds, they go to **** pretty quick when a 180 lb hotrodder plants his *** in them.
  24. Well, he put one in that car back in 04 and had it recovered and it has held up fine.
  25. silent rick
    silent rick
    i know a guy who replaced his after 4 or 5 years, said it was like sitting in a leaky beanbag chair
  26. Garry Carter
    Garry Carter
    Donzie told you what to do about two pages back ....
    Center seat our of a Plymouth Voyager mini-van, 2000 -- ???, works perfectly.
  27. pdunn10
    pdunn10
    I had always wondered this, plus they are a dime a dozen
  28. Mr48chev
    He might have to look at older Caravans. I think the mini vans got wider as they got newer. My wife is gone with the 91 she drives or I could measure it.
    I think my 88 Mini Ram Van is a bit narrower than her 91 but mine doesn't have back seats.
  29. brett4christ
    brett4christ
    I just picked up a 90 Mazda APV middle bench seat that fits my Tudor just about right. Seatback tilts forward AND reclines.
  30. Canuck
    Canuck
    Hey Brett, what's wrong with that blue, nice match for my coupe's seat.
    Looks like you have a bit more room width wise, I had to trash the plastic hinge covers to fit between the door posts.
    Canuck
