Jackson Roto Faze distributers...what engines, whos' got one??
Discussion in 'The Hokey Ass Message Board' started by SinisterCustom, Oct 26, 2007.
  1. SinisterCustom
    SinisterCustom
    Any guys here running a Roto-Faze??? Got pics?
    What engines did they make 'em for? SBC?
    I was at a shop awhile back and remember seeing one hanging on the wall. Didn't ask what it fit, but it 'appeared' to be for a BB Mopar. Had just the shaft with a tang.
    A Roto-Faze is just one more of those cool items I'd like to find......:D
    Any specs, info, history about these?:confused:
    Thanks Guys!!!
  2. Justin B
    Justin B
    joe panek is still making them up in l.a. but only on custom order and not cheap. if you're ever in his area make sure to stop by his shop there's some pretty amazing stuff there
    http://techccu.com/users/rotofaze/
  3. JimA
    JimA
    He comes by my shop- let me know if I can help in any way. Thanks Jim
  4. SinisterCustom
    SinisterCustom
    Thanks guys....are the dizzies made the same as always??? Is it a "traditional" part, so to speak? The website doesn't show much.
    Kinda looking for feedback on how they work and how well....
    I'll keep ya in mind Jim, thanks....
  5. plan9
    plan9
    Rotofaze has been around since the early 60s (might be a little earlier, but someone with more historical knowledge of the company can correct me), I'd say they would be at home in a traditionaly styled car.
    I have only heard good things about them....
    I spoke with Joe at an Antique Nats one year and he swears by points distributors, he said (not verbatum) "i like points because i can see a problem if it arises, more than likely they will never fail if you are on top of mainenance... an HEI is a little more difficult to troubleshoot visually...", I believe he is right, his explaination stuck in my head.
  6. Evel
    Evel
    The Kookie car has the best set up... 331 caddy with a Horn 4X2 and A Jackson Roto faze...Awwwww thats my dream.... if they ever come up
    they are EXPENSIVE!!! rich people stuff...
  7. SinisterCustom
    SinisterCustom
    Sell more VIDEOS!....hahaha!:D
    Looking at the pic, do these require two coils? How are they wired?
    The one I saw at that shop didn't have the two sides with 4 (at least that's how I remember it, need to go back)....it looked more 'conventional', maybe wasn't complete....:confused:
  8. RichFox
    RichFox
    I think the Kooky distributer is a Spalding Flame thrower. I have a Roto-Faze distributer on my Packard. Works fine, uses Ford inards. I also have a very low miliage Roto-Faze for a 270-302 GMC 6, could be used for a 235 type Chevy. For sale make offer.
  9. Sawracer
    Sawracer
    from socal
    I have one and besides the overhead it made the biggest performance difference in my model a ford. It's a points dizzy that has worked reliably at 9000 rpm, On race cars, not my old banger.
    It is an American made first cl*** over engineered piece, After a bad showing at a hill climb due to a piece of **** Mallory I decided only the best will do and I bought one. $450 is what i paid, and that involved some custom machining and welding. It's cheap for a hand made piece that comes with REAL Tech help. It looks tall as it is on a tower to clear my valve cover.
  10. brainfrz
    brainfrz
    Talk to Von Franco - like Evel said. It is a Jackson, Rich.
    Picture proof.
    Jon
  11. alchemy
    alchemy
    I bought a used Roto-Faze for a SBC years ago, it's the kind with one cap up top not the two out the sides. I haven't used it yet.
    I also have had a few Flamethrowers over the years, and they are a completely different animal.
  12. HEATHEN
    HEATHEN
    from SIDNEY, NY
    I've got a Rotofaze for sbc that's the style of the one on Sawracer's engine, and it's bolted to a turned down base from a '60s Corvette distributor to make use of the mechanical tach drive. When I picked it up, I thought that it was a homemade hybrid, but I've since seen two others constructed in the exact same fashion.
  13. RichFox
    RichFox
    Packard and GMC Roto-Faze distributers of current style
  14. Brock49Ford
    Brock49Ford
    The original Roto-Faze uses horizontally opposed caps. They are a true dual point dual coil ignition. The later ones that are produced are still dual point but single coil. Coil technology has come a long way since the late 50s when these were originally produced. Here are a few pictures of mine. The picture quality isnt that great but you get the idea. I got this from the original owner, he bought it new in '58.
  15. SinisterCustom
    SinisterCustom
    Brock....that's rad.....SBC???? Thanks for posting! And yer in Milton??? I work in Fife!
    I gotta find me one!!! Looks tall...I'd need to cut my firewall out some more, but it'd be worth it....haha....
  16. RichFox
    RichFox
    This was my way of making a duel coil. Of course on the Banger it fires two plugs, but on a V8 you just phase the roters at 90 degrees and run it like two four cylinder motors. These are 2000 Pinto distributers.
  17. Sixcarb
    Sixcarb
    from North NJ
    Defintley the coolest ignition ever made, this one is for a y-block, I'm looking for one for a early cad if anybody knows where the hidden treasures are.
  18. touchdowntodd
    touchdowntodd
    i would bet you can convert that yblock one to run with a caddy bottom end... seriously..
    this is like the ferrari of dual coils, i have the spalding, it works basically the EXACT same, but it doesnt have the cool fins and all.. ****py, but its all i got
  19. RichFox
    RichFox
    If you send that one to Joe Panack at Roto-Faze I'm sure he can make it fit a Cad, or most anything else with 8 cylinders.
  20. SinisterCustom
    SinisterCustom
    So, is there a set of points underneath each cap then???? How is the gap/dwell set?
    What's under the top cover???
    Curious minds want to know.:D
  21. RichFox
    RichFox
    I would bet it,s a worm gear drive to two 4 cylinder distributers mounted as you see. Under the distributer caps would be two 4 cylinder distrubuters and they would be set like any four banger. The ignition is just two four cylinder units on one crankcase. Like mine, but cooler.
  22. hisssss
    hisssss
    Sixcarb, Do you want to sell that Y-block Rotofaze? I desparately need one. Ron K 734-449-4951, ckrego@aol.com
  23. Von Franco
    Von Franco
    Sixcarb you can change the gear on your rotofaze find a stock cad dis .
    The rotofaze uses two coils and separate points they are 4 banger type points
    when I had the kookie car I had to learn alot on how to use and set the rotofaze.I also learned that when one set of points go`s out you only have one side of you motor working,so your 8 cyclender turns into a 4 cycelender.
    Also finding points was hard I found out ol willies jeep cap rotor and points worked .but that was then I don`t know if you can find that stuff as easy anymore lol.Hope that helps if you get one I`ll try to help....................
    Endsville Franco.................
  24. spoons
    spoons
    from ohio
    I just found one about a month ago....Here's mine...
  25. TV
    TV
    I have one of Joe's on our race Banger, It works great. It wouldn't clear our hood, so we took it apart{whoa} it is complicated, and cut it down. Joe came by the shop and shook his head that we were able to do it.I can't take credit for the job, as a friend that works for me did it. But it was a hard one.--TV
  26. steel rebel
    steel rebel
    Couldn't find an early one so I had Joe build one for my 50 cad engine, He put a crab cap on it. looks and works great. I have a small block Ford one with the wires out the the top that I would sell pretty cheap. The guy that just found one doesn't know how lucky he is.
  27. bushwacker 57
    bushwacker 57
    I also have a Y BLOCK tack drive dist. these were orig built KONG JACKSON. his brother PETE JACKSON. sold out to joe panek. I talked to kong years ago he said in 1957. he lost money trying to sell them. In the early 70s we sent joe two tach drive corvette dists to convert 75.00 ea. still have one. these dist are a work of ART.
  28. hisssss
    hisssss
    You can still buy original willies cap and points. Good tip Franco. Ron K
  29. hisssss
    hisssss
    $100 FINDER'S FEE to anyone who can help me find a Roto-faze dual point ditributor in any condition or enough parts to fabbed one up. Ron K, 734-449-4951, ckrego@aol.com Thanks to anyone who can help.
  30. hisssss
    hisssss
    $200 FINDER'S FEE to anyone who can help me find a Roto-faze dual point ditributor in any condition or enough parts to fabbed one up. Ron K, 734-449-4951, ckrego@aol.com Thanks to anyone who can help.
