Kingpin Axis Inclination
Discussion in 'The Hokey Ass Message Board' started by Jmountainjr, Oct 12, 2007.
  1. Jmountainjr
    Jmountainjr
    I tried a search, but couldn't find what I'm looking for. Does anyone have the kingpin axis inclination spec for a '32 heavy axle? I have an axle that was dropped "back in the day" by MorDrop. I've heard that some didn't hold camber that well. I figure if I checked the kingpin axis inclination before mounting the spindles and getting in under the car it might give me a clue of what shape the axle in really in. I just can't find a degree spec for what it should be. Thanks.
  2. pasadenahotrod
    pasadenahotrod
    from Texas
    From the 1936 edition of "Ford Service School Wheel Alignment".
    The sideways inclination of the spindle pin from vertical is 7 degrees. The angle of the spindle from horizontal is 2 degrees.
    Camber plus side inclination spec for 32-48
    Max. 9 degrees Min. 8 1/4 degrees
    Camber 32-48
    Max. 1 degree Min. 1/4 degree
    (Maximum variation between wheels is 1/4 degree. Camber of RH wheel should NEVER be greater than LH wheel)
    Caster 32-48
    Max. 9 degrees Min. 4 1/2 degrees
    (Max. variation between wheels 1/2 degree.
    Toe-in
    32-35, 3/32"
    36-48, 1/16"
    (Toe-in must be in proportion to Camber. Use ratio of 1 to 10.)
  3. Jmountainjr
    Jmountainjr
    Thanks. Yes I'm aware of the spindle component. I've got new spindles. I just wanted to check out the axle to try to get an idea if it may need to be bent to get back into spec.
  4. Bruce Lancaster
    Bruce Lancaster
    Make up 4 longish rods that fit or can be wedged into the perch and kingpin holes--then you can psycho****yze your axle by comparing and by sighting along your rods. Ends may ultimately need to be re-twisted to keep caster correct at finished ride height and for compensating for ch***is rake.
  5. 55 Mercury
    55 Mercury
    The inclination is 7 degrees. Put two long rods that fit tight in the king pin holes level the axle off the two perch holes. Then check the degree of your rods coming out of the king pin holes. They should both read 7 degrees. www.droppedaxles.com
  6. DarkVudu
    DarkVudu
    from Denton,Tx
    Anybody have any idea what it is for a 51 f1? :D
  7. 55 Mercury
    55 Mercury
    48-52 F-1 trucks are also 7 degree with a .8125 size kingpin. The right spindle off a F-1 is the same as a 46-48 Ford car spindle except it only has one tie rod hole since F-1 pickups were side steer and not cross steer.
  8. DarkVudu
    DarkVudu
    from Denton,Tx
    awesome, thanx for the quik reply ;)
  9. man-a-fre
    man-a-fre
  10. If you want to make some snug fitting temporary kingpins to mount your spindles, what I did before was take two grey plastic (ABS?) pipe ******s about 8" long and slit them lengthwise with a die grinder with a cutoff wheel. After you cut a slit in the plastic pipes, just tap them in with mallet. The tapered threads at both ends make it easy to get it started in there. They hold everything snug kind of like giant plastic roll pins, but they won't scratch the bushings. And just use a socket wrench and a rubber mallet to knock them back out again when you're done. The plastic pipe cuts like ****er with an abrasive wheel in a die grinder. I think I cut out a slit about 1/4" wide by making two p***es.
  11. I measured both ends of my '36 axle and came up with 8 degrees of kingpin inclination.
  12. 55 Mercury
    55 Mercury
