Replacement tire question
Discussion in 'The Hokey Ass Message Board' started by Gas Huffer, Dec 21, 2007.
  1. Gas Huffer
    Gas Huffer
    So, I had to temporarily replace my old bias plies with some cheap radials that were available locally (BFE, Nevada). The originals were "Sears" brand G78-14 and had seen many years of abuse. The problem is, they were about a 3" white wall and on top of that, the white wall didn't start at the edge of the rim. The problem I'm having is that if I stay with a 14" rim, I think I'm limited to a 2 1/4" white wall that looks too small from what I can gather based solely on the couple of pics I could find cruising the web. Does anyone offer a larger width WWW for a G78-14? Or if you have a set, if you could post a picture of them so I might judge a little better. Thanks.
  2. Gas Huffer
    Gas Huffer
    Is anyone using the Remington Candy Cl***ics? Any comparison to Cokers? I would tend to sway towards the Cokers, but the remingtons have a 2 1/2" WWW vs. 2 1/4. I know it's not much but I want as close to the set I pulled off.
