house of kolor, krome question?
Discussion in 'The Hokey Ass Message Board' started by JimSibley, Dec 22, 2007.
  1. JimSibley
    JimSibley
    has anyone used the hok krome paint? I am a little confused on how to leave the black before appling the krome.
  2. pimpin paint
    pimpin paint
    from so cal
    Hey Jim,
    For ''flash time'' between coats, I'm only guessin' that that's what
    your wondering about....HOK Tech Tips-urethanes/polyurethanes
    Use the "string method" touch spot closest to wetest spot sprayed
    release finger and look for "strings". When you no longer get the
    "strings" comming off the test area, it's ready to reshoot.
    House Of Color Tech ***istance #1-601-798-4229
    www.houseofkolor.com
    Happy Xmas!
    Happy Whatever!
  3. ab supply
    ab supply
    from fremont
    The black needs to be perfect..Like polished out with no dust or defects..ready for show,this way there is no imperfections that will show up when the chrome is sprayed out...
  4. chopolds
    chopolds
    from howell, nj
    The HOK stuff I used was easier to use than the original ALSA chrome paint. ab supply has it right, the chrome only looks closer to real chrome when the black base is PERFECT. Sanded and polished to perfection. Cleaned thoroughly, then the chrome and clear go on. Don't be impatient, let the black set up, cure, shrink, before continuing with sand and buff.
    Still looks more like a dirty mirror, than real chrome, so don't expect it to look exactly like chrome.
