Weiand Tunnel Ram ID help
Discussion in 'The Hokey Ass Message Board' started by Slomotion, Dec 27, 2007.
  1. Slomotion
    Slomotion
    I just traded for a tunnel ram for a BBC, but I don't know what kind of carbs it's set up for. They are smaller than 4150's, but that's all that I know. The casting # on the bottom is CR 1935 (Might be 1985) and it's for a square port BBC. Any clues on adaptors for 4150's would be greatly appreciated. It's an older intake and it has "SAY WHY-AND" cast into it. Thanks in advance!
  2. Slomotion
    Slomotion
    I was just playing with an adaptor plate that I had... The problem is mounting the Holley carbs sideways. Does anyone make an adaptor plate for this? Surely I can't be the first person to run into this!
  3. Slomotion
    Slomotion
    [​IMG]It's a one person conversation! I found the adaptor plates Edelbrock #2694
  4. 32HiboyRoadster
    32HiboyRoadster
    Sometimes its the only way to have an intelligent conversation! Congrats on figuring it out.
  5. saltracer
    saltracer
    I recently bought a tunnel ram at a swap meet. $120 for a SBF, I thought was pretty good. Well, after you buy two carbs and the special linkage to run the carbs side by side, and the small base distributor that's required for this setup....it wasn't so cheap anymore.
  6. Slomotion
    Slomotion
    I got lucky, it came with a fogger system, 2 Holley 650's, plumbing and linkage. All this for $300... not too shabby in my book.
    Anyone have any idea about what year this thing is from? Thanks!
  7. swade41
    swade41
    from Buffalo,NY
    Why won't the 650's work if they came with the intake ? You need 4160's to run inline like these two 450's I have.
