ol' flatbed pics please
Discussion in 'The Hokey Ass Message Board' started by 36dually, Dec 28, 2007.
  1. 36dually
    36dually
    from Colorado
    I am about ready to build a bed, and I would like to see some pictures to get some ideas on how to do it.
    I searched this site, google,... I didn't find any pictures that really showed the beds.
    Thanks
  2. Flipper
    Flipper
    from Kentucky
    My truck was originally a flatbed, but during the S-10 frame swap, I changed things around a bit (shortened it 10" or so , and raised it up to clear the rear tires). The only parts I re-used were the outer perimeter and the front and rear cross members. The rest is 1.5" square tubing and some wood.
    I don't have any great pictures, but maybe you can figure out what I did.
    FYI... it is not welded to the truck frame. It is mounted to tabs that bolt to the frame.
  3. 36dually
    36dually
    from Colorado
    Thanks
    that helped a lot
    Please keep them coming
  4. jrod60
    jrod60
    from Katy, TX
    I don't know anything about this one except it's sitting off I45 in Huntsville. This is the only picture I have of it, and probably isn't helpful, but it is a neat truck!
    J
  5. rusty1
    rusty1
    ...you could build a bed like this 37 Ford factory built bed with fenders underneath.
  6. PurplePearl50
    PurplePearl50
    from Sedalia,Mo
  7. 36dually
    36dually
    from Colorado
    interesting picture Rusty1
    my 36 1.5 Ton came with the front fenders and running boards(which end at the back of the cab)
    One idea I had was to make the bed fit between the tires (so it cuuld be lower)
    and attatch some kind of fenders to the side of the bed
  8. flynstone
    flynstone
    1952 fact 1/2 ton,46k orig mi v8 with merc heads,just a sweetheart......also my tow trk and aa the day i got her,,
  9. budd
    budd
    this truck has been for sale around here for awhile now, i think it would make for a nice mobile welding rig for me.
  10. 36dually
    36dually
    from Colorado
    budd
    thats just what mine looked like when I bought it
    here is what it looks like now
    here is a chop and channel I did with MS Paint
    What I was realy hoping to find was some real hotrod stuff like mabey some flames inlaid in a different wood
  11. JSC
    JSC
    The yellow one is what I started with and my brother still has the blue dump.
  12. rusty1
    rusty1
    JSC,...I got an F-4 that looks just like your yellow truck, same color....or it did til I took it all apart.
    ...here's a flatbed I built for a 39 Chevy (with 40 grille) truck I had years ago. I used lumber that I salvaged from a house that was hit by a tornado and some from a 100 year old corn crib. I cut 55 gallon steel drums apart to make fenders under the bed. [​IMG]
  13. rusty1
    rusty1
    JSC,...here's the F-4
  14. Bad Luck Engineering
    1941 Chevy 3/4 Ton Factory Flatbed
    My new project
  15. 36dually
    36dually
    from Colorado
    I didn't find as much inspiration here as I had hoped for but I knew exactly what to do when I was offered some free mahogany.
    Here is what I have come up with so far.
    I think I am going to inlay the v8 symbol in to it in aluminum diamond plate for traction.
  16. 9fingerdoug
    9fingerdoug
    from VA
    i welded some angle iron 2 the frame 4 a base
    then used pressure treated 2x's 4 cross members
    bed is t&g flooring attached w stainless srcews
    i recoat it yearly w/oil or deckstain
    not sure how 2 insert image#@%$#
    my avatar image shows the trk bed
  17. lackluster
    lackluster
    The mahogany looks great. I really like the look of the wide white dually's on there!
  18. Al's.C.D.T
    Al's.C.D.T
