checking bore depth??
Discussion in 'The Hokey Ass Message Board' started by crescentwrencher, Dec 31, 2007.
  1. crescentwrencher
    crescentwrencher
    is their a way to check bore depth with out pulling the heads???
  2. Dan Hay
    Dan Hay
    Hahahahaha... I've got a dirty mind.
  3. yekoms
    yekoms
    Pull the pan... Need more info what brand engine? 4cyl,6cyl,8cyl, V or inline?
    Is it in the car. Some cranks can be identifide by the rear flange shape.
  4. yekoms
    yekoms
    Hey I'm thinkin' about the crank stroke. Is that what you are askin"?
  5. crescentwrencher
    crescentwrencher
    im tryin to figure out if an engine is a 360, or a 390. the guy i bought it from wasnt sure.
  6. mungo
    mungo
    from Australia
    Pull out a spark plug ,turn that cylinder to TDC,measure top of piston to plug hole,turn crank 180 degrees, measure again and the difference between the two is the stroke
  7. crescentwrencher
    crescentwrencher
    i was thinkin thats how u were supposed to do it but i wasnt sure, thanks!
  8. yekoms
    yekoms
    Yep it's like Mungo said.
