1934 ford sedan question
Discussion in 'The Hokey Ass Message Board' started by Abomber, Jan 2, 2008.
  1. Abomber
    Abomber
    IN UR OPINION WHAT DO YA THINK ITS ALL WORTH?
    1934 ford tudor sedan body VERY Nice, minor rust and dents, one spot of bad rust on the below the p***anger side rear window, has about 80% of original floor, really nice, NO garnish mouldings
    34' Frame rails and X member are taken apart.
    1955 Olds Rocket 324 and hyrdomatic ******
    1932 ford Heave axle dropped 3" over stock
    i have a few people interested in me parting it out, but Id like to see what you all think its worth together.
    im NOT trying to sell it but I was interested it what you guys thought its worth in case I descide to sell it later
    Thanks!!!!!!
    zach
  2. Roadsir
    Roadsir
    Kind of an odd request, but I'll bite. body looks nicer than most, frame looks good, ~$5500 to ~$6000?
  3. Pewsplace
    Pewsplace
    If you are just curious here is what I found when I put an ad on Fordbarn. 1933/4 Ford bodies are less expensive than Deuces and that is a good thing. Good bodies with all the interior stuff can be purchased in the $7,000 $10,000 range with marginal fenders. Bodies only run in the $5,000 to $6,500 with frame. If the frame has a CA pink then add $1,500.
    If viewing your pictures here is my estimate.
    Body and frame $4,500 - $5,000
    Axle, ebay $6-700 if lucky
    Motor $500 unless rebuilt then $1,000.
    Keep it and put it together low buck and sell it for $25,000.
    Good luck.
  4. ss34coupe
    ss34coupe
    depends how muc later you want to sell it. Its only worth what someone will pay right now. The stuff you have appears in good shape and would be a great start for a traditional hotrod. I would say $5000-6000 would get some bites. There are still a lot of unbuilt tudors around, and they do not compare with coupes in value.
  5. plan9
    plan9
    ill tell you pewsplace is off target by a longshot and i wont tell you what its worth either... thats for YOU to figure out by your lonesome.
  6. Abomber
    Abomber
    i have an idea of whats its worth, i was just seein what you all thought,
    thanks to all who helped!
