Do YOU have 4, 6 or more CARBS on your HotRod ? Stand Up if you do !
Discussion in 'The Hokey Ass Message Board' started by AHotRod, Oct 2, 2005.
  1. Tudor
    Tudor
    from GA
    good thread - glad you brought it back up to the top - maybe one day I'll be able to post something kewl!
    Thanks for the info on the ox sensor Kerry- I have been thinking about doing that but didn't know if it would work on zoomy type pipes.
  2. SinisterCustom
    SinisterCustom
    So, do you have 4, 6, 8 or more carbs on your HotRod ?
    4
    What `combination ' are you using "
    Weiand 4x2, Stromberg 97's with stock .045 jets and stock PV. 350 SBC, big cam...carbs are progressive (Eelco linkage), outers are primarys
    Did you do it 'Yourself' ?
    Yes
    If not, who did your set-up, and are you pleased with the quality, performance and price?
    Do you "really" drive it allot ?
    Yes
    Have you pulled out all of your hair trying to make it run worth a **** ?
    Not really, but it did take some time getting the carbs all operating the same.
    Would you do it again ?
    Yep.
    I want to hear it from you, and post some pictures of your set up if you will.
  3. roosters hot rods
    roosters hot rods
    only have three:(..but they work *****in:D,and on the center 2brl it gets 20 mpg :D...i like that at 315 a gallon...rooster
  4. Kerry
    Kerry
    Wow Glenn. I'd completely forgotten about this thread. Now I've only got two carbs but they're early Pontiac AFB's on a 671. :)
  5. Stone
    Stone
    Oneday I will have something with 3 or more.
  6. Terry O
    Terry O
    These will sit on top of the 348 stroker Curt Harvey built.
  7. hot rod pro
    hot rod pro
    from spring tx.
    i'm going to run a man-a fre 4-2 intake on my 32 pickup i'm building.
    -danny
  8. crazycummins
    crazycummins
    dont mean to steal the thread, but what type of fitiings and flare did you use on your fuel line setup. i like it alot. im trying to stay away from rubber, and this is what im looking for.
  9. GMC BUBBA
    GMC BUBBA
    Ran 5 "97s" on my 322 GMC six with howard manifold for some time. After a couple years , took them off for a redo by the ****ster 27 will reinstall them this summer.
    They ran good and i put a few thousand miles on them including driving to the hundred car show a couple years pulling a teardrop camper...:):)
    Now are they a pain , sure they are! But are they cool you bet !!!!
    No pain run one four barrell. Cool? Run as many as ya can..:eek:
  10. Dirty2
    Dirty2
    I have 4 94's on my 51 331 Caddy. I also have a 6 ,2 set up, but need 2 more 94's. I love multi carbs !
  11. stinsonart
    stinsonart
    My oldest friend Ken's '51 Merc. Former sedan (now a convertible, all work done by Ken), runnin' eight Harley Davidson carbs on a manifold made from an old tunnel ram. Motor is a 429 Lincoln. Ken made the manifold and turned the air cleaners himself. Works like a charm!
  12. crazycummins
    crazycummins
    do you guys run certain carbs, like ones with or without chokes, and idle circuits?
  13. ratrod0
    ratrod0
    327 chevy 4x2
  14. ratrod0
    ratrod0
    on the car
  15. desoto
    desoto
    from Ayer, MA
    Probably a weak spring in that 50+ year old power valve is the culprit. Try swapping in a set of new power valves frm those good folks in the UK.
  16. desoto
    desoto
    from Ayer, MA
    Four
    Cragar manifold. Stromberg 97 carbs. (rebuilt w/ oversized throttle shafts) .045" jets. Progressive linkage, Run on the two center carbs, end ones open on demand. All four accelerator pumps are hooked up and working.
    Cagle vacuum controlled fuel pressure regulator.
    Used to run a Weiand 4 carb manifold, but that needed to be run with straight linkage or it'd starve the 4 end cylinders due to the runner configuration. The Cragar is an open plenum manifold.
    Center carbs have working chokes.
    Gets about 14 mpg. The roller cam and 12.5:1 compression don't help matters since I've retarded the timing a bit to diminish the tendency for spark knock and I run a thick head gasket to lower the compression a tad for the street.
    Yes. Made my own linkage, sanded and polished the manifold. Put 12 degree ****erflies in the end cabs. Bent my own fuel lines (5/16' Steel tubing, no neoprene lines) Made the heat shield to keep the front carb base from expanding and squeezing the throttle shaft (THAT was "interesting" when it happened) because the front carb is nearly touching the remote thermostat.
    1000 miles each way to Louisville every year plus a whole lot of other places but that's the long trip every year. [​IMG] Been to Bonneville (from M***) with it a couple of times as well. Actually, I drive the snot out of the car once I get behind the wheel. With a 53 gallon gas tank, I can go a ways between fill-ups and I tend to make the 1000 mile trip home from Louisville in one shot (gotta be at work on Monday marning)
    Nope, got it dialed in really easily when I first swapped from a Holley back in the spring of '94.
    Sure
    [​IMG] [​IMG] [​IMG] [​IMG]
  17. Alfster
    Alfster
    I run 5 single barrel stromberg carbs on my GMC 270 six. Hand made intake. Took ages to get it to run right. Uses adjustable main jets.
    Previously ran 6 x 2's on a hand made intake on a Y block.
    Would I do it again???? Hell yeah.......................
    Real hot rods have lots of carbs.
      57.6 KB
  18. Kerry
    Kerry
    Thanks for the suggestion Skip. Right now the Stromberg setup is sitting on the shelf waiting for another project. I'll check the power valves then. I stuck a blower on her about a year ago with a pair of Pontiac AFb's. :)
  19. desoto
    desoto
    from Ayer, MA
    The power valve is only actuated when the accelerator pump plunger hits it and forces it open but the return springs got rusty if the carbs were left empty and they'd loose their tension and the power valves would start to leak.
  20. AHotRod
    AHotRod
    That is a sweet looking engine !
  21. Tindall
    Tindall
  22. Vergil
    Vergil
    Running 4 94's on 8ba but cheated and stuck fuel injectors under them.
  23. Alfster
    Alfster
    A couple more pics.
  24. Gepetto
    Gepetto
    from Orange
    that first picture you posted was jimmy white's model A (hemi coupe) that thing runs like a bat out of hell. He used to drive it all the time, but now it has been sleeping for about 3 years or so.
  25. AHotRod
    AHotRod
    Go wake him up !!!!!!
  26. ilikeflatblack
    ilikeflatblack
    from HASLET, TX
    heres mine. intake was done by salt flat matt @ geardrives.[​IMG]
  27. cracker head
    cracker head
    jimmy, are you listening? :D
  28. AHotRod
    AHotRod
    Wild and Cool setups guys !
