front end shakes bad???
Discussion in 'The Hokey Ass Message Board' started by chopt56merc, Jan 15, 2008.
  1. chopt56merc
    chopt56merc
    from fullerton
    ok I have a 56 Merc and when driving front end starts shaking so bad steering wheel shakes too. Replaced swaybar bushings need help what to look for thank you
  2. atch
    atch
    one of the most overlooked and common culprits is a separated tread on a tire. did this happen all of a sudden or get worse gradually?
  3. Ole don
    Ole don
    After doing what Mike said, the very next thing to check on any 54 thru 56 Ford or Merc is the front crossmember where the lower A arms attach. These cars have an excellent front suspension, but this is a rust prone area. Parts are easily available to repair these front ends, and they work very well.
  4. Kramer
    Kramer
    If you don't find anything from what was mentioned above, have the wheels checked for balance.
  5. Gotgas
    Gotgas
    from DFW USA
    Was FoMoCo using ball joints by '56?
    Sounds like a bad ball joint or tie rod end shimmy.
  6. Crankhole
    Crankhole
    Get it up firmly on jack stands and have someone wiggle the tire while you look underneath. Probably ball joints as Gotgas suggested above.
  7. Nick79
    Nick79
    from Austin, TX
    If ya gots bias plys try some different wheels and tires up front. Quick and easy way to check if it's wheel/tire related. Mine started shakin about 55-60 and went away at about 70. Switched to radials and the problem went away.
    Nick
  8. Check the idler arm.
    I had a 54 Ford coupe that did the same thing.
    Bought it from a guy at work about 62.
    He bought it for his daughter.
    Price, $125.
    I offered to fix it for him, he offered me the car for $90.
    I bought it, one $9. idler arm later I was sailing down the highway with no probs.
  9. chopt56merc
    chopt56merc
    from fullerton
    it was all of a sudden and i do have bias plys i will check the rim and tires switch them ball joints look good i was told ****** mount or u joints could it be that??
  10. Nick79
    Nick79
    from Austin, TX
    To check the u-joints/driveline, put the back of the car up on jack stands (facing in a safe direction) and get in and drive it a bit. If the vibration is still there, it could be the driveline. If not, most likely it's somewhere in the front end. Start isolating the issue and that will help you find your problem.
    Nick
  11. Unkl Ian
    Unkl Ian
    Check EVERYTHING.
  12. chopt56merc
    chopt56merc
    from fullerton
    hey unkl thanks for the tip haha thats the feeling I got too
  13. Unkl Ian
    Unkl Ian
    Tie rod ends,Idler Arm,shocks,wheel balance,
    tires out of round,loose wheel bearings,.....
    Keep looking.
