GM 1 wire alternator on 394 ci brackets?
Discussion in 'The Hokey Ass Message Board' started by cisco88, Jan 16, 2008.
  1. cisco88
    cisco88
    My 55 olds has a 394 in it. I spoke to this guy once and he told me that there is a way of hooking up a GM 1 wire alternator by doing a little modification on original brackets. Now, I've reach the time to install the alternator on my ride and I was there last night going crazy and could not figure it out. If there is anyone out there that knows the procedures on how to do, please, let me in on this.
    thanx:confused:
  2. scrappy
    scrappy
    Pictures may help, but if you can't fab that bracket to work ... check some local speed shops - they ususally have a few different brackets on the shelf and you may get one to work. If nothing local braket-wise, you can always try summit racing. Have you tried mounting it in a different area that "stock"?
  3. cisco88
    cisco88
    Yeah, I'll definetly will check local speed shop, but i would rather use what I have already. Hoping someone here might have done it already. I have not tried mounting it any where else. I was just so into trying to figure out how to use the exsisting brackets.
  4. scrappy
    scrappy
    Yeah I hear ya. You may try drilling a new hole or mounting it in a different place, like on the block or other head. What is your problem - is it mounting or holding the alternator? You may try different bolts/sleeves to get it to work...
  5. cisco88
    cisco88
    Anyone else have any ideas?
  6. Paul
    Paul
    Editor
    use the alternator brackets off a '63 or '64 394
  7. cisco88
    cisco88
    The motor is off a 61'. What is the difference and how will it work.
