Can quarter elliptical springs be splayed?
Discussion in 'The Hokey Ass Message Board' started by cubed, Jan 16, 2008.
  1. cubed
    cubed
    from Canada
    Can quarter elliptic springs be splayed or do they need to be parallel to each other?
  2. 61bone
    61bone
    Wouldn't be a good idea. The springs will bind in the pivots. Even parallel they do some, but having them splayed out would make the bind unacceptable.:)
  3. Unkl Ian
    Unkl Ian
    If you run shackles,they can be splayed.
    Without shackles,they want to be parallel.
    Do a mock up,with just the main leaves,to prove it.
  4. The37Kid
    The37Kid
    Bugatti used splayed rear springs on all the Type 35,37 and 51 GP cars, they worked just fine. The attachment end needs to be forged so it is parellel to the axle. Overland used the setup in the 1920's.
  5. cubed
    cubed
    from Canada
    You lost me at: "The attachment end needs to be forged so it is parellel to the axle"
  6. They can be REALLY splayed, you just need shackles
    Willys-Overland 1924 had this setup too, gotta find the pics I have of Poor Boys Ed's ch***is
  7. cubed
    cubed
    from Canada
    YES please find me pics! ;)
  8. Unkl Ian
    Unkl Ian
    I think he means the eyes of the spring are "formed"
    so they are parallel with the axle at ***embly.
    Another possibility.
  9. OoltewahSpeedShop
    OoltewahSpeedShop
    Are you wanting to splay them to avoid using a panhard bar? I'm working on a project using them to and wondered the same thing.
    Thanks,
    Kevin
  10. cubed
    cubed
    from Canada
    I am going to use them in the rear of my A , the frame is originally splayed, so I was just going to mount them to go along with frame. I'm not sure about deleting the panhard, it poses an interesting question though.
  11. Why no transverse spring?
  12. You can splay them with an air complessor.
    Good luck.
  13. R Pope
    R Pope
    The Overland had the front springs splayed at a 45 degree angle with no problems. The "A" frame is only ten deg. or so, shouldn't matter.
  14. The37Kid
    The37Kid
    I can't find a photo, but the main leaf were the eye is rolled is bent inward so the bolt is in line with the axle housing, otherwise it will bind when moved.
  15. Unkl Ian
    Unkl Ian
    Don't need a panhard bar with leafs,even if they are on an angle.
    Even at 45 degrees,not a problem.
    A lot of guys don't run them with transverse leaf springs.
  16. Unkl Ian
    Unkl Ian
    That is what shackles are for.
  17. fab32
    fab32
    Surprised no one has mentioned that many OE's use unparallel leaf springs to cancel oscollations in the suspension. You don't need as heavy shock action with them mounted out of parallel, thus a softer ride.
    Frank
  18. hudsoncustom
    hudsoncustom
    I don't see why it would be an issue. Hudson ran unparallel leaf springs under the "step down" cars.
    As long as the shackle end of the spring was parallel with the shackle (in line with), I don't see an issue.
    If you design the ch***is along the same lines as you would if you set up a coilspring rear you'd be OK I'd think. Most of those don't run parallel trailing arms either.
    Then again, I'm no ch***is tech, and I'm not sure if this is what you meant by "splayed"...
  19. GMC BUBBA
    GMC BUBBA
    I have a 25 chevy truck in the shop now ( a customers) that has factory (orginal equipment) splayed front quarter elliptical springs. i will snap a pic tomorrow.:)
  20. cubed
    cubed
    from Canada
    Looking forward to seeing a factory setup.
  21. cubed
    cubed
    from Canada
    After seeing an A that Pinkees Rod shop built with sectioned duece rails, rear quarter elliptics and X-mem ahead of rear axle, it has tons of trunk space and sits nice and low....
  22. cubed
    cubed
    from Canada
    Anybody have any luck with pics of splayed springs?
