I.D. this blower?
Discussion in 'The Hokey Ass Message Board' started by A32Flathead, Jan 8, 2008.
  1. Anyone? It says KAISER on it, but its on a Ford engine...any ideas? After market or original equipment on T-Bird?
    :confused:
  2. squirrel
    I think McColloch would put whatever name you want on the plaque if you bought enough of them!
  3. Bruce Lancaster
    Bruce Lancaster
    There was a McCulloch blown stock Kaiser. Really.
  4. Thats what I thought...cool set up tho!
  5. banjorear
    banjorear
    Second that.
  6. shpotty
    shpotty
    from New Jersey
  7. HEATHEN
    HEATHEN
    from SIDNEY, NY
    Specifically, it was the Kaiser Manhattan. Kaiser's last ditch effort to stave off the effect that the horsepower race had on their sales.
  8. You would have thought they would have put the Supercharger on the Darrin instead of the Manhatten, althoughthe Darrin already had problems running hot and the supercharger would have only made it worse I imagine.
  9. buger red
    buger red
    from dallas
    its a mccoulah off of a early fiftys kiaser frasier but the tbirds had a model
    made by mccollah that would operate on wide open throttle switch that would
    open and close the pully to speed up the blower
    thats a cool set up man
  10. Shaggy
    Shaggy
    from Sultan, WA
    Yea how in the hell did it work with the switch???
  11. yellow wagon
    yellow wagon
    from WI
    that blower is REALLY cool!
  12. Never seen Mad Max ;)
  13. Basically, you are moving the sides of the pulley in & out to change the drive ratio (changing the pulley diameter as the belt rides farther up the slanted sides, or down)....Paxton did this a couple of other times, with a Ford blower, & a self-sold aftermarket unit, in the '50s. Interesting idea but not very successful so far as durability/reliability.
    If you happen to see an older John Deere lawn tractor with a "variator"...it's the same idea. Just move the lever & the tractor speeds up or slows down, without stopping and changing gears....all done with the primary belt drive from engine to transaxle.
    Didn't work too well on the JD, either. :rolleyes:
  14. jonny o
    jonny o
    That's pretty trick! First pic does have a pretty deep pulley on it, although it might just be locked out somewhere in the middle.
  15. vendettaautofab
    vendettaautofab
