ford econoline
Discussion in 'The Hokey Ass Message Board' started by Stude-sled, Jan 13, 2008.
  1. Stude-sled
    Stude-sled
    I have the chance to buy 2 ford econ vans. They are parts only, are they worth much in parts? Does anybody need anything from them? Yes both front axles are still under them. Thanks.
  2. garvinzoom
    garvinzoom
    If you can get them cheap enough and there are good parts the popularity of those vans seems to be very good at the moment. See what good parts they have and then hit EBAY to see what they are going for.
  3. Ford Freak
    Ford Freak
    You should be able to sell the front axles. Lots of g***er's being put together these days.
  4. Toast
    Toast
    from Jenks, OK
    If there was a truck I need a tailgate!
  5. Hellfish
    Hellfish
    I need some sheet metal... the front corners with the turn signals in particular. You can part them out on ebay. SOme parts are worth some bucks. Many parts are Econo only and not reproduced. The sway bar, for example, has been regularly going for $75. If they are 65-67, the crossmember is valuable to anyone doing a v8 or big 6 swap. If it's a 67, the dual MC is worth a lot.
  6. guiseart
    guiseart
    front ends, seats, windsheilds, and sheetmetal are sellers... get 'em.
  7. Fredo
    Fredo
    from So Cal
    Yes, if you can get them for a good price they are worth parting out.
  8. butch27
    butch27
    If one is a '67 I'll buy the master cylinder from you.
