Trunk pan replacement
Discussion in 'The Hokey Ass Message Board' started by jub, Jan 19, 2008.
  1. jub
    jub
    from York, Pa
    What is the best way to replace a trunk pan?
    Overlap and spot weld or but and weld complete?
    It's a 67 caprice if it maters
  2. SaltCityCustoms
    SaltCityCustoms
    The best way is to **** weld, then you will have no seams and nobody will ever know you were there, the overlap would create a space for moisture to get in in eventually rust out your seam.
  3. jub
    jub
    from York, Pa
    I was going to do the perimeter as a but weld, but the center piece is flanged on each side and I was going to spot weld this. It's a three piece replacement pan. Will that be good?
