302 efi to carb ?
Discussion in 'The Hokey Ass Message Board' started by wyoming, Jan 19, 2008.
  1. wyoming
    wyoming
    from My house
    so i've got a 302 and aod out of a 88 marquis and i want to convert it to carb and put it in my 55 fairlane what distributer do i use and any other things i need to know ?
  2. The Shocker
    The Shocker
    My ranchero has an 87 H.O. 302 in it ,with an old tunnel ram and a Mallory point type dist.I think any 289-302 intake will work fine on your motor ,as will a any point type dist ...
  3. Maricopa
    Maricopa
    I'm doing this right now and using a Duraspark from Car Quest #REB 30-2831
    You probably know this but you'll also need different valve covers so you'll have a vent and a PCV.
  4. tjm73
    tjm73
    The '88 Grand Marquis SHOULD not have a roller cam. So you shouldn't need a steel distributor gear. But this is not a guarentee. Make sure you use the correct gear for the cam when you use ANY carb compatible distributor.
    When you have the intake off you will know it's roller cam if it has what looks like and is called the spider in the valley cavity.
    If you plan to use the AOD, do a bunch of research to learn about potential problems and make absolute sure its TV cable is set properly or it will burn up the tranny and do so rather quickly. The AOD is a good tranny but it has a few particulars that must be paid attention too. An auxillary tranny is a must as are a shift kit and the proper setting of the TV cable. I can't stress that bit about the TV cable enough.
    Some will say the AOD is junk. They don't know what they are talking about. Lastly do not do the first-drive-first shift trick to get and hold 2nd gear. it's the number 2 destroyer of AOD's. Following improper TV cable adjustment.
  5. wyoming
    wyoming
    from My house
    thats what i had heard can i use an old points type dizzy and just change the gear or do i need a special dizzy?if it is a roller
  6. Flat Ernie
    Flat Ernie
    Tech Editor
    You can use any 221/260/289/302 distributor. If you've got the roller cam, you just need to make sure the gear on the distributor is correct...
  7. tjm73
    tjm73
    If it's roller you only need to have the correct gear. Any 289/302 distributor will work. And it uses the 351W firing order too if it is a roller. There are 2 distributor shaft diameters that I know of, so make sure you get the correct gear if you have to get one.
  8. Frank
    Frank
    Assuming your doing away with the smog junk, you have to plug the back of the heads where that crossover pipe bolts on. I've seen it covered in another thread. I believe folks use a threaded plug.
  9. wyoming
    wyoming
    from My house
    got the the head holes covered and i know I'm going to use a eclectic fuel pump
  10. misfit36
    misfit36
    from new york
    im in the process of doing the same. mine is an 87 out of a mustang with T5. i need a dizzy with a steel gear
  11. 40chev
    40chev
  12. FritzTownFord
    FritzTownFord
    tjm73 seems to know his shit.
    Wish I had know this sooner. I used a '79 302 distributor (NAPA # 48-2899) in my '90 5.0 - ran great for two years. Then gear melt down!! If you don't have a roller motor it will work fine.
    Campare the distributor shaft depth cause some early numbers seemed too short to mate with the 5.0 oil pump shaft.
    I used the AOD - Lokar shifter/TV cable kit is staightahead, but I had a local trans shop look over my settings. If I had to do it again I'd go with a C4 cause mileage is not great anyway. Good luck.
  13. Kustom Komet
    Kustom Komet
    If the engine has a factory roller cam, then the best distributor to use is the '85 Mustang GT five speed model, the only steel gear, roller cam compatible, carburetor type distributor they ever made. It has a Duraspark plug on it, so you can do a simple Duraspark conversion or use it to trigger an MSD box, either way works good. Most good auto parts stores can get you a reman, but it must come from that specific car.
    If it is a flat tappet cam, then as stated earlier, you can use any 260-289-302 (non roller) distributor with points or Duraspark, available in boneyards everywhere.
    -KK
  14. silent rick
    silent rick
    what about the oil pump drive shaft? do you need a different length? i was told when running a carb on a roller motor and switching everything over, i had to change the oil pump drive shaft too. they said, sure, the old shaft reaches but it barely makes contact. the engine builder had a few fail(strip out?), so they now recommend changing them. supposed to be an 1/8 or 3/16 inch difference between the two different shafts.
    anybody else hear this? i guess if you had both styles of distributors side by side, you should be able to tell if the efi one is slightly longer. anybody have both distributors laying around to make the comparison?
  15. silent rick
    silent rick
    sorry, just read this now. as stated in my post above, check the oil pump drive shaft for adequate engagement. ford does sell a longer shaft. the last thing you want is to lose all your oil pressure on the highway.
  16. punkabilly1306
    punkabilly1306
    from ohio
    water pump rotation is a big one, those motors are set-up for serpentine so if you decide to go v-belt then you'll probably need to get a new water pump
  17. redoxide
    redoxide
    Im also mulling over a swap from the trouble free injection ( but worrying to hook up) to a carb ... but need to ask where can you source V belt pulleys for this motor that have the 4 bolt holes to mount to crank ?
    On the other hand are there any EFI experts in the house can work out whats required to make the EFI run . Mine is in an F1 truck, would like to keep it but hook up worries keep me questioning the benefits ...
    This may not be a strictly trad engine, but its whats fitted in the Cole Foster built 36 ... so it cant be that bad a choice!!
  18. wyoming
    wyoming
    from My house
    ive got all the crap to hook up the efi its not that hard i just decided to go the other way if you have a donor car to get a harness from its only two wires to hook up
  19. wyoming
    wyoming
    from My house
  20. project40
    project40
    80's Ford trucks used v-belts ;)
  21. tjm73
    tjm73
    I'm 99% positive that Crown Vic's, Grand Marquis and Town Cars used standard rotation.
  22. OneRustedDodge
    OneRustedDodge
    I'll be doing this sometime next month, thanks for all the tips!
  23. redoxide
    redoxide
    great stuff, thanks for that ..
    was it only the HO motor that had a roller cam?
  24. redoxide
    redoxide
    does that mean there will be EFI spares available? being in the UK ( Scotland ) its not always that easy to find this stuff... Im thinking its going to be a tad costly just now so might stay with the EFI , see how it goes, then take it from there .. I can do with spending the cash in other areas of the build .. If I cant get mine to run itll be swiftly back to plan B :)
  25. fast Ed
    fast Ed
    All 1986 and newer passenger car 302s (HO or not), as well as 1994 and newer truck 302s, had factory roller cams.
    cheers
    Ed N.
  26. tjm73
    tjm73
    That is not always correct. They all were roller compatable. But not all are roller equipt.
  27. fast Ed
    fast Ed
    That's interesting, I'm just going by what the Ford parts catalogue shows. I'm guessing then that you've actually seen post-86 cars with a flat tappet cam? If so, I stand corrected. :)
    cheers
    Ed N.
  28. tjm73
    tjm73
    I have. With Ford, what they say they made isn't always exactly what they made.
    From 1985 till 1995 the H.O. engine had a roller cam. It came in all V8 Mustang's, Thunderbird V8 Sports, Cougar XR7's and Lincoln LSC's. Crowns, Grand Marquis, Town Cars, F150's, Vans and all other 5.0/302 V8 engines could have been roller cam engines, but may have been flat tappet engines. Depending on what and when it was built. By the early to mid-90's most everything had changed over to the roller cam. All 5.0 V8 Explorers and Mercury Mountainers were roller cam until the last 5.0 powered vehicle left Ford in 2001.
  29. mattcrp1
    mattcrp1
    85 and up 302 had roller cams and will need a gear. the firing order is different from a h.o. motor its all in the cam so if you change the cam to a h.o. cam should work ok. i saw an h.e.i. style distributor converted to a ford body and that seems like a good cheap way to go all it need is a 12v off the ignition switch
  30. mattcrp1
    mattcrp1
    from what i have seen any block with the one piece rear main seal was a roller cam. @85 and up. i have seen where the gears get worn when the gear wears out but mostly on older cars. any way when you get the intake of to go carb you'll know for sure
