56 Ford sreering box questions
Discussion in 'The Hokey Ass Message Board' started by 56KUSTOM, Jan 20, 2008.
  1. 56KUSTOM
    56KUSTOM
    I found a NOS steering box for $75!This one has some kind of cap on top of the locking nut where mine has the adjusting screw.Anyone know if that is supposed to be pried off to get at the screw?
    Also should I put gear oil or STP in it?
  2. fordhaulers
    fordhaulers
    I put STP in my 56 f100 box 5 years ago and have had no leaks or problems yet. My buddy is an old hotrodder from the sixties,he has a original 32 roadster from Calif. with a 56 box and a brookville 32 roadster with a 56 box. the original car was purchased in 1959 and he said that he only uses STP in his boxes. So good enough for him me too !
  3. HotRodFreak
    HotRodFreak
    I use STP in early Ford steering boxes, also in the Mustang nonpower box in my 32 ford.
  4. 56KUSTOM
    56KUSTOM
    Any answers on the adjustment question?
  5. 56KUSTOM
    56KUSTOM
  6. 55RAT
    55RAT
    If the cap is a hex cap,try unscrewing it.I had a 41 Plymouth that had one.Once you unscrewed it,the screw and locknut were visible. Just a shot in the dark...:rolleyes:
  7. vintage56
    vintage56
    here's the real question, where did you score a NOS 3CC03 box for $75?
  8. butch27
    butch27
    Yes: Inquiring minds want to know.
  9. showrod
    showrod
    sounds like the cap you refer to is the lock nut/ cap it should have the large star washer thing under it. if so unscrew it and adjusting screw is underneath.
  10. 56KUSTOM
    56KUSTOM
    Auto Roundup magazine.
  11. junkyardroad
    junkyardroad
    from Colorado
    Use the oil. Grease won't circulate, and it will wear a flat spot on the gears.
  12. 56KUSTOM
    56KUSTOM
    Thanks for the help guys.
