Ca Title Problems Are Over!
Discussion in 'The Hokey Ass Message Board' started by DKING, Jan 22, 2008.
  1. DKING
    DKING
    from LAS VEGAS
    10 months ago i bought a 54 bel air from cal.***le was all good in cal.checked to make sure it was clear before i bought it.When i took it back to vegas i did not know their is a vin check for out of state cars before you regester it.(yes i am stupid)Well the vin did not match the ***le.This is because cal. use to take numbers off of the motor back in the 50s.Well the motor been replaced 3 times Any how i fought the nv and the cal.dmv for 10 months with no head way.I saw that some hambers had talked about i.t.s so i went on the web site and it sounded so sketchy but i said f it.130 bucks 12 days i got my paper work.I took it to the nv dmv 20 min. later i had a plate and sticker.Ten days later (today)I am holding a new ***le in my hand.I am so stoked.My car is legal now.
  2. MotorBike Mike
    MotorBike Mike
    Good for you!!! I'm using that service for sure next time!!!
    Mike
  3. Terry
    Terry
    Good for you!
    But I'm wondering, didn't the number on the ***le match the VIN number on the car?
  4. Mr48chev
    When I bought the 48 the PO had taken the time to go to the Texas dmv and have it noted that the truck had had a motor change. It sure made things easier when I moved back to WA.
  5. DKING
    DKING
    from LAS VEGAS
    no again call me stupid.I did all the cal info but never checked with my own two eyes live and learn.ethier way that service will help a lot of guys out.
  6. lotus
    lotus
    from Taft, CA
    it is very common for the ***le and vin tag to not match up on old cars in cali. old cars each had there own standards and things would get screwed up.
    I have talked to highway patrol officers that sort out these issues and they say it is common. dmv would sometimes grab the wrong number. block id/body id/any other string of numbers that might be on the car and use that at some point.
    quickest way to sort it out if you notice that the ***le and vin do not match is to store the ***le away and go into the dmv with the car and say you lost the ***le. there is paper work to fill out but they will just go off the vin tag and get you a new ***le.
    also, to the original poster congrats on getting your california dmv mess sorted out! on my truck all that is holding me up is i have to get it weighed. then mail all of the paperwork off then i will have a new ***le.
  7. Docfranknstein
    Docfranknstein
    What was the name of the site You used to help with the paper work?
  8. DKING
    DKING
    from LAS VEGAS
    international ***le service
  9. Out of Las Vegas. I had to do the same thing and they were very fast!!! Walked into the DMV and within about 3 minutes I had a temp plate and about 2 weeks later I had the plate for the car and another week ,had the ***le. Great service. Looks like the price has gone up!!!
    http://www.its-***les.com/15price.htm
    I know a guy that brought his 26 Buick to the Vehicle state inspections and they issued him a new vin# even though the vin on the frame was different. Its an ugly ***ed aluminum plate that he took off as it looks so ****py. If he went through ITS, the ***le would have matched the frame!! Doesnt make sense not to use these people. Then it makes the frame legit to the ***le.
  10. DKING
    DKING
    from LAS VEGAS
    Wow its up to175 now .Still worth every penny.It just makes it almost to easy.
  11. 35mastr
    35mastr
    from Norcal
    Now will this service work for the cars without ***les in california?
    Will the DMV accept their paperwork?
  12. 35mastr
    35mastr
    from Norcal
    I have a 1929 Pointiac coupe.I bought from a guy here in Lodi.He gave me the actual pink slip from 1958.Will the DMV still accept this as the ***le?Or is there a different road I need to take??Back in those days the Pink Slip was the ***le.I havent even seen one of these in over 20 years.Has anyone tried using the old style pink slips.The serial on the pink matches the serial on the frame.
    I would like to get this part done before spending any money on the build.
  13. DKING
    DKING
    from LAS VEGAS
    yes it will.
