!!!Texas City UGLY Truck H.A.M.B. Thrash!!!
Discussion in 'The Hokey Ass Message Board' started by Richard D, Jan 8, 2008.
  1. rab71
    rab71
    I built my own cones for my headers. I took three inch diameter pipe and cut them from basically nothing to two and a half inches at the other end then I squeezed it in a vice and shaped it with a hammer as well. I obviously tack welded then finish welded and ground the weld smooth. Didnt take that long.
  2. Kev Nemo
    Kev Nemo
    Go Stingrays!!!-in Austin, that's all the help I can offer...
  3. Actually the high school mascot is the Stingarees, I'm surprised anyone would know about that? Richard grew up in Freindswood so probably didn't even know.
    Casey, don't worry, I'll be there standing in for you in that capacity.
  4. Actually, I did know. Jeepers Creepers is from League City, if I remember correctly. But then, I drink a lot of beer, so what do I know?
  5. I pasted this from the build thread, I had to work late and didn't get to mock it up. Matbe tomorrow.
    Got my axles over the weekend. They did a nice job. I used Sid(55 Mercury) baecuse he did the spindles as well as the axle, and modified the $35 kingpins, I forgot what year, and made new thrust bearings, for $20, so I didn't need to buy the $120 kingpins, even had them brought back to Houston for free.
    www.droppedaxle.com
    After dropping the steering arms to match, re welded and re-tapered the holes so I can mt. the tierod underneath. I would use him again with no problem.
    <!-- / message --><!-- sig -->
  6. Those things look like they got rained on!
    It don't look good for me this week-end, helping Kisam on that house. She,s got a Feb 1st deadline. After that; I'm in. Got all the bearings now for the 350. Get that bead roller built before the week-end, you're gonna need it!
  7. houtex63
    houtex63
    from houston
    sorry i won't be able to lend a hand, i got my own problems to worry about. i'm knee deep in work til april.
    i hope you get your truck running in time for roundup so you can leave your chearleader suit at home, lol...
    j/k pu&#241;etas, good luck on the build.......
  8. We are mocking the axle as I type.
  9. Dan Hay
    Dan Hay
    Aw man, I just got off a cruise ship in Galveston on the 13th and drove back to FTW... I woulda stopped for a couple hours had I known..
  10. tcoupekyle
    tcoupekyle
    Hey Richard, I got a few sets of SBC headers they are for trucks and **** but if you need a set I'll give them to ya. Oh and by the way Dayton beat them stigaroids or whatever in the playoffs.
  11. tcoupekyle
    tcoupekyle
    I also have a set of jahns pop up pistons for a 283 if You want one for a shift knob or whatever let me know its yours, or if you'd like to use used pistons let me know and I'll give them all to ya.
  12. pasadenahotrod
    pasadenahotrod
    from Texas
    To mount the 40 Ford brakes to the 32-36 spindles no spindle modification is required at all. You have to install a bearing spacer on each spindle and a centering ring for the backing plate, available from any early Ford parts house as a hydraulic brake adapter kit. The mounting holes in the backing plates must be elongated to fit the smaller bolt pattern of the early spindle.
    Bolt on and done.
  13. I know about that method, this way (Done by NealNC here on the H.A.M.B.) looked much stronger. I should probably do it the old way, been done by hundreds(thousands?)over the years, should be O.K. for me.
    We sure could use a guy of your experience to come lend a hand, I'm sure everyone would like to meet you.
  14. I definitely want the headers and pistons, I have some low compression jobs right now.
  15. If you "really" want to make it to the round-up.
    Get the engine, brakes etc rebuilt, while you do all the busy work like finish welding, etc. Don't wait till the last minute to do these things.
    Keep the parts flow going.
    You can do it, bro.
    AND, easy on the beer, the welds just don't look as good:D, and spend more time on the car, than on the HAMB:eek::eek::eek:
  16. Good advice, Dreadman.
    Change of plans, I bought this today out of the cl***ifieds. I'll save the more exotic cowl steering setup for the RPU. It will need to be reversed, but I hear that is a really simple procedure. '62 F100 box and column. Anyone done this particular one?
    I will mount it as a unit, on top of the framerail, instead of on the side. Will be stronger, and probably make for a better steering wheel angle. If I find I don't like it, it's just cutting/grinding and welding. I'd prefer the key on the dash, but will leave it as-is for time being, since it works.
  17. tcoupekyle
    tcoupekyle
    So... I spoke to richard on the phone earlier, and we made sure he can use the pistons and maybe the headers. One problem... Richard lives in Texas city, and I drive a 40 year old truck, thats a little worn out. Therefore, anyone who lives somewhat close to Baytown and is going to the thrash... PM and we'll get together and if I ain't busy if it would be okay to ride with you and bring some parts, via your not so worn out Driver. If I can't make it, I could still arrange for you to bring the parts. The parts are set of 8 pistons, A Rear spring, two wheels, and a set of headers. Thanks
  18. Brad S.
    Brad S.
    Dammit Richard.
    It just dawned on me that you're doing this during MARDIS GRAS! You had better have some damn ****ies there and I don't mean yours. :D
  19. MUNCIE
    MUNCIE
    from Houston
    Hope you can get it road worthy.Im working weekends all this month night-shift to top it all off.Good Luck
  20. Are you going to Mardi Gras here, or in New Orleans? I am 10 min. from Galveston, you could leave from here and go join the long lines, crowds, etc. I'll watch it on Girls Gone Wild.
  21. MUNCIE
    MUNCIE
    from Houston
    Hope the thrash is going well....
  22. MUNCIE
    MUNCIE
    from Houston
    Would love to one day am I at work right now.I work nights and this is my month to cover weekends.:( I'm right off i-10 and sheperd.:cool:
  23. El Caballo
    El Caballo
    from Houston TX
    I'm in Houston now, I'll come and bear a hand if I decide that a conjugal visit back to Borger is not required. Go ahead and PM me your address so I can mapquest you. Maybe jabber and I will both come, depends on schedules.
  24. hotrodtodd
    hotrodtodd
    from Houston
    Richard, great idea. I would be there on the 26fh, but I am in the same boat. Good luck and hope to see that ulgy SOB there.
  25. CHANGE OF PLANS
    Dave(Xtralow 60) has offered the use of his shop. He has more room, and more tools. This will be closer for everybody as well.
    Dave's shop address for Mapquest:
    112 Campbell Ave.
    Pasadena, TX 77502
    Ph# 281-216-2775
    As a bonus, you will see some really cool in-progress hot rods and lowriders they are building.
    Thanks in advance.
  26. Brad S.
    Brad S.
    Shaun's coming by to help me finish the floor in the roadster. Actual sheet metal instead of wood and a bona fide battery box which won't be located directly under the bolted in bench seat. I've been working on it and thought I'd finish it by this weekend.
    Anyway. We're planning on at least swinging out for a little bit. I'll at least try and drink a few with you before we take off. I need to get this finished. It's holding me up.
  27. Friday A.M. bump.
  28. Friday P.M. bump.
