O/T 70 cuda spec.? Anyone
Discussion in 'The Hokey Ass Message Board' started by MIKE47, Jan 25, 2008.
  1. MIKE47
    MIKE47
    from new jersey
    I know this is O/T but I figured I'd give it a shot. I am doing some resto work on a 1970 plymouth cuda. I need to know the distance apart the rear leafs should be at the axle pads. Either pin centers or inside to inside once ***embled. Something ain't right in this car and I need to figure it out asap. I know someone on here has one of these cars or knows of a good mopar website. Any help is appreciated. Thanks, Mike.
  2. 6t5frlane
    6t5frlane
    from New York
    Allpar.com I think is a good Mopar Forum
  3. JOECOOL
    JOECOOL
    I don't have the spec but I do remember the springs don't set paralell with the frame. Hope that helps. best of luck.
  4. LUX BLUE
    LUX BLUE
    Alliance Vendor
    from AUSTIN,TX
    they taper in from the front...Like a shallow "v"
    The pins aren't centered in the springs, either. they sit about 1/3 down from the front bushings.
  5. texascuda
    texascuda
    from Dallas, TX
    GO over to Cuda-Challenger.com or I can give you the spec's on Saturday.
    Regards,
    Steve
  6. SinisterCustom
    SinisterCustom
  7. RodStRace
    RodStRace
  8. moparron426
    moparron426
  9. MIKE47
    MIKE47
    from new jersey
    Thanks guys. I really appreciate the help. Guess I gotta cut off the pads. They are 44". They were just done by another shop "to factory specs." Guess they got the specs. from the wrong "factory".
    I knew they tapered in towards the front and that there was a left and right. Now I just gotta pull it all out and start over.
