inch lbs. = foot lbs. question
Discussion in 'The Hokey Ass Message Board' started by 41woodie, Jan 25, 2008.
  1. 41woodie
    41woodie
    The torque wrench I have measures ft./lbs. I need to tighten something to an inch/lbs setting. Is there a conversion between the two? My guess would be that 60 inch/lbs would equal 5 foot/lbs of torque but just dividing 60 by 12, but it's only a guess.
  2. D.W.
    D.W.
    from Austin Tx.
  3. noboD
    noboD
    Yes, divide by 12. I would not use a ft.lb. torque wrench for that low of a setting. If you are really talking about 5 ft.lbs., that's hardly hand tight.
  4. 41woodie
    41woodie
    Well if I'm using the conversion table correctly it shows 60 inch lbs. = 3.125 ft. lbs. That doesn't make sense, but I always hated algebra because they weren't interested in the answer they wanted to know how you solved the problem.
  5. FiddyFour
    FiddyFour
    that conversion page kicks ***... thanks D.W.
  6. blown49
    blown49
    Blower on my Merc had to be torqued to 14 in#. If it's critical spend the money for the in# wrench you'll prolly be glad you did.
  7. Mr. Creosote
    Mr. Creosote
    Your correct. 12 inch pounds in a foot pound... Most foot pound torque wrenches start off at 20. And are most accurate in the middle of their range, least accurate at the top and bottom of their range. Does anyone know a link to a table for average torque specs for most bolts?
  8. V4
    V4
  9. Ebbsspeed
    Ebbsspeed
    Shows 5 Ft./lbs when I use it.
  10. 50 Ford 1963
    50 Ford 1963
    I second this...
    You'll probably spend more fixing what you broke than what you would on a new torque wrench. ask me how I know this...:mad:
  11. Jalopy Jim
    Jalopy Jim
    I have been working for the past 2 days fixing someone else mistake: NOT using an inch pound torque wrench on a Camery aluminum head.
    Had to make a steel plate to fit the top of the Toyota head, use a magnetic base drill, and drill out the broken bolt, only to find out today two other bolts were over torqued and the thread will not hold 168inch pounds.
    So they have to be drill to 8mm bolts and taped.
    Save yourself some time and money and get an inch pound torque wrench.
    Jim H
  12. HotRodChassis
    HotRodChassis
    Alliance Vendor
    I'll second what Jalopy Jim and the other are suggesting. Buy the right, quality tool. A cheap torque wrench will give you inaccurate torque values, and more work later. You get what you pay for.
  13. Digger_Dave
    Digger_Dave
    A THIRD from me!
    When I was working on some electronic gear; the fastener torque values were ALL in INCH POUNDS.
    After screwing up a couple of - expensive - ***emblies; I invested in a GOOD INCH POUND wrench.
    (you would be surprised how much torque a HAMB :D (sic!) handed person can apply!!)
    One word of advise; if it will be used a lot, have it re-calibrated each year to insure accuracy.
  14. 41woodie
    41woodie
    Well I already own a snap-on "click" when it's at the right spot ft./lbs wrench. Guess I'll see if they have one for inch/lbs. I've found that using the very best tools and the most expensive parts usually help offset my lack of knowledge and talent.
  15. Mustang65
    Mustang65
    Just tighten her down snug then give another turn....That's how we did it on the farm
  16. Sour Kraut
    Sour Kraut
    You mention drilling and taping to 8mm, if the original bolt was a 6mmx1.0 the correct torque is 89lbs./in. not 168. You may have an incorrect spec.
    The correct torque for an 8mmx1.25 bolt will be 18lbs./ft. or 216lbs./in. That is ***uming grade 8.8 bolts are used.
    If you need to repair a threaded hole, use a Helicoil insert. They work excellent if used correctly.
  17. TudorJeff
    TudorJeff
    First off, the people who are suggesting to spend the money on a good torque wrench with a range made for the torque you are targeting are offering great advice.
    Secondly, if you need to convert things, one of the best ways is to go straight to Google and just type it in like so "convert 60 inch pounds to foot pounds". Google will give you the answer plus it will work for all kings of conversions.
