Body Filler- What's the good stuff these days?
Discussion in 'The Hokey Ass Message Board' started by newstranger, Jan 27, 2008.
  1. newstranger
    newstranger
    It's been a good long time since I've dove into the dusty world of body filler, so I thought I'd ask before I start skimming the patch panels on the coupe. Years ago I exclusively used DynaLite and really liked it compared to other brands. This is around the time that all the Rage products first came out and I have to admit... I thought the Rage stuff was pretty lame in comparison. The only reason I mention this is it seems a lot of people on here seem to really like it.
    Anyways, if you guys could shed some light on the body fillers of today I'd really appreciate it. Things probably haven't changed all that much... speaking of which, does Evercoat still make the best finishing putties, etc.
    Thanks much,
    ns
  2. SwitchBlade327
    SwitchBlade327
  3. I second the Rage Extreme!!
  4. SlowandLow63
    SlowandLow63
    from Central NJ
    I relied on Evercoat's Lightweight and Z-Grip for a long time. I tried Rage Gold for the first time and loved it. I haven't tried Rage Xtreme, but I don't doubt these guys are like me.
  5. Rage Gold is good, but if the Extreme is better............
  6. raffman
    raffman
    Rage Gold is good but I prefere the Basecoat/Clearcoat, it's a little smoother.
  7. Chad s
    Chad s
    huh?
  8. publicenemy1925
    publicenemy1925
    from OKC, OK
    Rage Gold and Metal Glaze here.
  9. Pickledilley
    Pickledilley
    I like TAC FREE body filler myself! Sands good & it spreads very good!!!
    "PICKLE Dilley"
  10. K13
    K13
    Evercoat has a new line of fillers and putties coming out called Quantum. They are a brand new technology. Hybrid polyester epoxy with a 10:1 mix ratio rather than 50:1 of traditional fillers and putties. They sand much better and will not shrink due to the epoxy. There will also be two different catalyst available for different temperatures so you can control the work time without under or over catalizing your product. They should be very cool.
  11. Chad s
    Chad s
    When are these expected to be available?
  12. K13
    K13
    They should be coming out right away. They were introduced at NACE and SEMA. I know they did a bit of a test release in Florida this month so it should be soon.
  13. SaltCityCustoms
    SaltCityCustoms
    I'd like to know when these will come out also, I am working on an airplane at the moment and the airplane industry recommends an epoxy based filler that i am using but it sands like a rock but sticks to anything even non-prepared surfaces and it extremely hard.
  14. K13
    K13
    I would say check with your local Evercoat distributor they can check with the local rep to find out an date for you.
  15. 54Caddy
    54Caddy
    from Visalia,CA
    I used Rage Gold on my Caddy. This stuff is great. I also used some old shcool filler LEAD, I had fun playing with that.
  16. rustypipes
    rustypipes
    from san jose
    I use rage and evercoat (Easy Sand) stuff rules
  17. Terraizer
    Terraizer
    Rage Extreme is great stuff. Sands great, levels out good and no pinholeing.
  18. oilslinger53
    oilslinger53
    from covina CA
  19. David Totten
    David Totten
    RAGE GOLD beats them all.
  20. UnIOnViLLEHauNT
    UnIOnViLLEHauNT
    I like Evercoats cheap blue can, its super everweight or something like that. Its like 10 bucks a gal and works really well.
  21. newstranger
    newstranger
    I like the sound of polyester filler/putty... I used to spray polyester basecoats quite a bit (DuPont and R&M) and shrinkage was never a problem... polyester good... just get a good respirator... fresh-air setup even better.
    -ns
  22. Richard Head
    Richard Head
    It is called Evercoat Lightweight. I hate that stuff. Rage extreme costs three or four times as much and it is well worth the money.
    Dave
  23. slamdpup
    slamdpup
    FANTASTIC made by upol....try it you will be HOOKED
