Tech: custom steering wheel
Discussion in 'The Hokey Ass Message Board' started by nicanor, Jul 6, 2005.
  1. pigpen
    pigpen
    from TX USA
    Great tech! I like the watch idea. I have an old Timex laying around that just may get pressed into service. :cool:
    pigpen
  2. GO-rilla
    GO-rilla
    Wow, thats pretty cool.
  3. airkooled
    airkooled
    from Royal Oak
    Great tech! My VW steering wheel has cracked over years of weathering and that putty sounds like the ticket.
    The clock talk made me think of this little desk clock I have. My wife used to have a SAAB. They send you little "gifts" after you've owned the car for 6 months, a year, whatever the interval is, I don't know. This clock would be perfect for this steering wheel job. Maybe you can find one on EBay sometime. The clock piece press fits into the surround, and a rubber O-ring makes the fit perfect. For some reason when SAAB sends you the clock, the batteries run out almost immediately, but it takes a regular watch battery and then it works great.
  4. Circus Bear
    Circus Bear
    Incredible, I am always humbled seeing **** like this. Looks great. Also looks cl***ier than a citreon wheel. Would look greatin a custom. Please post pics of the actual car this things going in.
  5. Per request, here's my project but that wheel may not be going in it, probably just sell it and just start modifying wheels on the side for others?? I'm planning on putting a tilt/telescoping column on this project so the wheel can't be used anyways. My bug's chopped, sectioned, channelled, body relocated back 10" (for an extended front axle look), raked and reshaped doors, custom dash, semi-Z'd frame, etc. Sits about 48" high right now. More info on the mods at www.RuntRod.com
    Dash started from '49 Ford vert, shortened and rearranged:
  6. Just an update on the progress, I finished the trim, just polished for now but will be nickel plated in a couple days. I made it from 1/4"x1" flat bar steel I had laying around I bought awhile ago from Home Depot. I welded beads on top of each other onto the back and grinded it down to a pin-shape to help grab the wheel some more, will probably by glued into place as well for good measure.
    I actually put on a couple layers of black today but screwed it up (first time I shot urethane paint so wasn't used to it). So have to sand then re-prime then try it again. But it sure does look purdy in black
  7. painted black (though need to strip it back to re-prime, but you get the idea of the finished product)
  8. Backbone11
    Backbone11
    Anyone know where to see the pics in this post?
  9. 4woody
    4woody
    I'd like to see them too.
    Did anyone save them?
  10. jonzcustomshop
    jonzcustomshop
    better late than never....
    I found some shots of this guys wheel.
    the last 2 shots are citroen wheels, a71, and one more modern.
    the very last shot is nicanor's finished product.
    There were 2 71 citroens at the local wrecking yard, and I could not figure out how to get the wheel out! It is attached to the column!
    those cars are crushed now... so I think I will try this guys vw trick.
    neat tech.
  11. ploon
    ploon
    some more pics of a few of his wheels
    http://www.runtrod.com/sale.html
    my only concern is about the strength of the wheel, seeing as it's got one of the spokes cut out of it
  12. jaxx
    jaxx
    pics of my custom wheel - hand built - ready for a leather wrap
  13. ttarver
    ttarver
    from austin
    red x's for me?....
  14. Clever idea and nice work, but I'd be worried that the single spoke would eventually break off due to constantly being flexed back and forth.
    V-Dub wheels are probably similar to GM wheels in that the spokes are fairly small diameter and the plastic doesn't do much for the strength of the wheel.
  15. ugotpk
    ugotpk
    This is my little project.
