Primer
Discussion in 'The Hokey Ass Message Board' started by tpw35, Jan 29, 2008.
  1. tpw35
    tpw35
    Has anyone used the duplicolor primer? I primed the falcon yesterday and had a hard time getting the consistancy right, the directions say mix it 50/50 with their thinner, when I did this is came out of the gun like spider webs, When I thinned it enough to shoot it took alot of coats to cover? Todd
  2. 40chev
    40chev
    I have used it a quite a few times and have had good success with it.... I usually sprayed it fairly thick yet wet, it fills nice and sands out good also...Maybe try opening the needle a little more?? If it is too warm outside or in the garage and you use the low temp reducer you'll have webs....
    what pressure are you spraying at?? what gun??
  3. tpw35
    tpw35
    An older fritz gun at around 30-40 psi. It was in the 50s outside and I was using their medium to fast reducer.
  4. dirty mikey
    dirty mikey
    from chicago IL
    have used it before,worked good
