1935 Plymouth, Should I get it?
Discussion in 'The Hokey Ass Message Board' started by bcharlton, Jan 29, 2008.
  1. bcharlton
    bcharlton
    from Buffalo NY
    I need some help. I am still working on my 1931 5 window Oldsmobile. However, this car became available. It is all original and drives. I can get it pretty cheap. I like it becasue I can put more then two people inside. Does anyone have any pics of their 1935 Plymouths?
    How about turnuing it into a hotrod?
    Let me know.
    BC
  2. If you don't want it, let me know where it is so I can go get it....
  3. rustyford40
    rustyford40
    from Mass Bay
    Get it put a hot mopar engine in it. Don' put the same old sbc in that ****s
  4. bigaadams
    bigaadams
    from Georgia
    I think if you have the means to buy and hold the unit you should...if you later decide not to build maybe make a buck or two on resale if your "deal" is really good. face it..this iron is not made anymore but also keep in mind that little aftermarket is "keyed" around this car..making it the better, more challenging build.
  5. Circus Bear
    Circus Bear
    Agreed. BUILD that thing. those don't need much to make a nice looking family cruiser. Drop it on chryseler spokes and toss in a 360/727 combo. Using the standard mopar p*** side offset they prety much drop in. I think Plydo even has motor mounts. Or if you a real man like bigaadams and I stuff in a Big Block. :)
  6. bcharlton
    bcharlton
    from Buffalo NY
    Does anyone have any pics of a finished car? I would love to get some ideas from finished 35 Plymouths. I may pull the trigger this week. Any ideas of what a working and complete car is worth?
    BC
  7. bcharlton
    bcharlton
    from Buffalo NY
    Here is another picture.
  8. 1320Paul
    1320Paul
    Buy that car, then buy a pinstripe suit, fedora, and drive that ***** around. That thing is sweet.
  9. Personally, I don't give 4 doors a second glance.
  10. revkev6
    revkev6
    from ma
    didn't those have the double hump front axle and hydraulic brakes?? seems to me that would make a cool quickie hot rod build. fix up the stock stuff that you can and insert bigger motor!
  11. bcharlton
    bcharlton
    from Buffalo NY
    I agree. I would put in a bigger motor and be dome wth it. I real simpy build.
    BC
  12. 50dodge4x4
    50dodge4x4
    Should be able to find pictures at www.carnut.com look in the car picture index, under Plymouth, then 1935, then 4 door sedan. 35 and 36 Plymouths are about the same.
    The flathead 6 was a good motor. With a few b***ic hot rod mods, like split exhaust and two carbs, they ran pretty well. In stock form they would run down the highway at 60-65 all day if it had the od. I had an advertisment stating the top speed was something like 75mph in 35! The Chrysler corp cars were light years ahead of the GM and Ford products of the time. Gene
  13. HOTRODSURFER
    HOTRODSURFER
    from HATBORO,PA
    buy and drive it!
  14. go get it and drive the **** out of it..
  15. BOBBY FORD
    BOBBY FORD
    Wouldn't have to do much to make that a bad *** ride. I'd buy it if reasonable. Looks like it is complete right down to the wheels! I'd buy it and drive the **** out of it while smoking a big cigar.LOL
  16. plym_46
    plym_46
    from central NY
    Take a look at the "Plymouth the First Decade" website. Some good info regarding 28 to 38 Plymouths. The trimed porthole trim on the hood indicates it is the upscale model. Humphry Bogart drove a 2 dr version as Sam Spade in several movies. See it it had the Bogart option, a flip down panel with two pistols that helped Boggie out of tight situations.
    Plymouth went through a couple versions of front suspension 34 through 36, odly they went from a IFS set up back to a beam and leaf springs for 1 year and then went back to IFS.
    Engine will be a 80 HP give or take 201cu in flat 6. If you can see cylinder castings on the drivers side of the block its an early engine. Some time in 35 36 they went to a fully jacketed casting. Those artillery wheels are definately keepers.
    Here is some info from the All Par site. Model Designation is PJ. Lotsa pics on carnut.com
    http://www.allpar.com/history/plymouth/1935.html
  17. danagamer
    danagamer
    no, do not buy that car. However, could you please send me the phone number that was written on the side of the door?
    :D
  18. Searcher
    Searcher
    Pretty sure this is a 35, but it's a coupe.
  19. Dyce
    Dyce
    I helped my father in law rebuild a later dodge engine for his '35 plymouth 2dr. I's a nice original. It is a fun car to putt around in. They are a nice car. Hydraulic brakes, open drivline, straight axle up front, full pressure oiling. His is geared low. It will run down the road nice at 60 but any faster is pushing it. Looks like a nice car. Hood onament is snapped off. Hard to find peice..........
    Jeff
  20. gecko54
    gecko54
    from Sumner, WA
    Check out the '36 in the new R&C ...Slamit and have room for company when cruz'n or "Family Car".
  21. 39cent
    39cent
    from socal
    I had one way bak, an old geezers work car. He had parked it after retirement, and it was just sitting in his backyard. Was ***e an solid car, motor was kind weak but it perked up after some miles on her. They have a strong frame and hydraulic brakes, make a good cruiser. I would do a slant 6 and a 5 speed and drive the hell out of it
  22. bcharlton
    bcharlton
    from Buffalo NY
    Thanks for all the input./ I am working out a deal now. I am planning on dropping in my SBC and going with a a little rake from front to back. Please pm me with any finished pictures of the car as a street rod/hot rod
    Brian
  23. Circus Bear
    Circus Bear
    It's your car, but I beg you to please keep it mopar. If you must put in a SBC Plydo has a motormount kit for you.
  24. moparron426
    moparron426
    here are a few more pics for you:cool:
    I too say "PLEASE,PLEASE,PLEASE" use a mopar in your mopar:D Ron..
  25. ArtGeco
    ArtGeco
    from Miami
    Well not exactly, but here's my Buddy Matthole's 38.
    It had been in a warehouse for 35 years, it's now a daily driver.
  26. Six Ball
    Six Ball
    from Nevada
    Get it if you can. It'll be easier to get rid of it than to find another one! I'd keep the 6. Eddy Edmunds made heads and multiple carb manifolds for Mopars. There is a lot of engine build info at inliners.org.
  27. Suicide rear doors make it a push, as in cards.
    A slant 6 would be the Shiite.
  28. klazurfer
    klazurfer
    Just dreaming .. :eek:
    Klaz
  29. plym_46
    plym_46
    from central NY
    Actually they are 5 windows, but your version does look right.
  30. myoldcrap
    myoldcrap
    Looks like it's in really good shape! Hell buy it and drive it for a while then have some fun with it!
