straight axle ifs?
Discussion in 'The Hokey Ass Message Board' started by fordrock, Jan 30, 2008.
  1. fordrock
    fordrock
    i was reading in a book and it mentiond something about a dropped tube axle split in the midle used like an early form of IFS have u ever seen this do you have this on ur ride?
  2. zman
    zman
    from Garner, NC
    it ****s, great in theory, *** in reality... there are a few people trying to p*** it off again...
  3. upzndownz
    upzndownz
    it was a hot setup on sprint cars back in the 30's sort of faded away after that
  4. junk yard kid
    junk yard kid
    there is a new one they sell, and an artical in a hot rod mag 6 months ago
  5. FiddyFour
    FiddyFour
    fatman sells a kit to convert a beam axle to center mounted ifs... i remember a thread a while ago where someone explained the ill effects on camber and handling as the beams moved independantly...
  6. T McG
    T McG
    from Phoenix
    They work fantastic when the car isn't moving.
  7. Unkl Ian
    Unkl Ian
    Looks good in the magazines.
    Consider it a step down from the Ford Twin I-beam suspension.
  8. vintagehotrods
    vintagehotrods
  9. dumprat
    dumprat
    from b.c.
    Go look at a two wheel drive ford pick up. Up to 1997
  10. FiddyFour
    FiddyFour
    yes, and no... the longer axles on the pu's make for less actual camber change.
  11. Shaggy
    Shaggy
    from Sultan, WA
    Allards had em too used ford axles
  12. NeilageInc
    NeilageInc
    If you split the beam, it then turns into twin beams. Twin beams are the dumbest parts ever invented and they handle like ****. Don't do it you'll waste your money.
  13. Kerry
    Kerry
    Yep, Grandpa's Twin I Beam suspension in his 64 Ford pickup rode like... well... a pickup.
    I have seen a setup on a roadster where the left axle attached to the right frame and the right axle to the left frame do decrease camber change. Still doesn't sound like a great idea to me.
  14. Shaggy
    Shaggy
    from Sultan, WA
    If allards ran it i cant see it's all bad, if set up right, definatly not like a modern style ifs but still probably works ok
  15. Gotgas
    Gotgas
    from DFW USA
    You just end up with a system that handles no better than a normal straight axle with transverse spring, is ugly, and is complicated. It's not a new idea, guys were doing it in the '30s on hillclimb compe***ion cars. Ford's long I-beams got it about as perfect as it will likely ever be, go for a drive in a '96 F150 and tell us what you think. ;)
