Let me see sum engine turned pieces...PLEASE!!!!
Discussion in 'The Hokey Ass Message Board' started by lockwoodkustoms, Jan 29, 2008.
  1. lockwoodkustoms
    lockwoodkustoms
    I am thinking about doing a little engine turning on my 39 Ford . But i would like to see what you guys out there have done this to. All types of metals are what I am looking for for ideas.
    Thanks
  2. The Brudwich
    The Brudwich
  3. lockwoodkustoms
    lockwoodkustoms
    I was wondering if any other Hambers out there have done this before?
  4. raven
    raven
    Yes, Hambers have done this...
    r
  5. frozen_bohemian
    frozen_bohemian
    from Minnesota
    I made a sprint car wing for my KoolerKart.
    Just a drill press and a scotchbrite disk. You can also use a dremel sized wirebrush for smaller swirls.
    Still needs paint and finishing..............
  6. lockwoodkustoms
    lockwoodkustoms
    That is one sweet little ride. I like the engine turn as well. I was wondering if you can use a wooden dowl and some abrasive compound to get the results, this way you can use any size dowl out there.
  7. Shaggy
    Shaggy
    from Sultan, WA
    What's the contrast in texture look like in different methods, and what is the right way of doing it??
  8. NaKpinstriper
    NaKpinstriper
    Yes, you can use a wooden dowel and lapping compound. It workded well for me and thats how a lot of the old machinists do it. Just make sure that the end is square(so that the whole thing touches the metal),if you don't do this your swirls won't look very good. I stuck my dowel in the lathe and faced the end.
  9. Here is a dash insert I did for my son's '62 Chevy truck. I used the green Crotex stick laying on the table
    Tony
  10. Terry
    Terry
    Whats a crotex stick? Awesome look BTW
  11. tommy
    tommy
    How about some with 75 years of aging? The flash brings it out. It has a nice patina in natural light.
  12. I meant Cratex. It is a rubberized abrasive stick. Here is the link:
    http://www.cratex.com/
    Tony
  13. raffman
    raffman
    Here's a little somthin FPM metals did for me, firewall to match. They even cut out the holes with a laser. What ****s is I had the job done before they joined the alliance......[​IMG]
  14. FLAT-TOP BOB
    FLAT-TOP BOB
    HAMB O'dex Editor
    fpm did this insert for my merc.
      62.5 KB
  15. Ryan
    Ryan
    ADMINISTRATOR
    The dash in my '38... and the wheel in my a-coupe.
  16. Here are a couple pieces I did in aluminum for my track roadster. One is a bracket to hold the throttle cable for the webers and two heat shields for the underside of the carbs.
    Charlie
  17. I have only done this once, so I am no expert. That being said, here is the method that worked for me.
    Clean the aluminum with soap, water and a green Scotch-Brite pad. Towel if off well. I has to be absolutely clean.<O:p</O:p
    <O:p
    Screw a ¾” plywood board (larger than the piece being turned) down to the drill press table. The plywood should be wider than the drill press table so the fence can be clamped on easily.</O:p
    <O:p
    Clamp on a straight fence (a 1 x 3 ash strip works well).
    <O:p</O:p
    Chuck Cratex stick in the drill press. (I experimented a bit and found the 3/8” diameter to look the best for what I was doing).
    Turn the drill press on and run the tip of the Cratex down against a piece of course abrasive paper. The sticks tend to round over and get dirty, so this needs to be done at about every half-row or so to clean the tip and square it to the sides. (I even took mine out a couple of times during the process and squared it up on the lathe).
    Put a pratice piece on the table and apply a swirl (I started at the bottom row).
    Build a cadence, because each swirl needs the same application pressure and time.
    Move the piece over enough to get a ½ to 1/3 overlap. (I just eyeballed mine).
    You don’t have to move the fence when you get to the end of a row, just swing the table until you get the correct overlap (again ½ to 1/3 and eyeballing it works just fine). At some point you will have to reposition the fence and move the table back to the starting point. (I maybe moved my fence twice).
    The most important thing is doing each swirl exactly the same. No one will notice if a swirl is off by .020 inch, that is why eyeballing it works. It will, however, be immediately apparent when the application of a swirl does not match the others. That is why dressing the tip often is so important.
    Tony<O:p</O:p
    </O:p
  18. CRH
    CRH
    from Utah
    Here's one I did for the '27 roadster- it's a piece of br*** from a door sill plate. Harbor Freight hole saws were a joke, and this is only br***! The engine turning got a little lazy- I was just messin' around. What I mean is, one should probably build a fence or use guide lines, instead of following the perimeter of the shape with the swirlies!
  19. fordsteel
    fordsteel
    from Elkland PA
    mines a first attempt not that great probably redo it someday. done on the drill press with a homemade tool.
  20. lockwoodkustoms
    lockwoodkustoms
    Well Dave,
    I will be over to see this soon. :)
    And Ryan who did the wheel. That is badd ***.:D
    I am wanting to do something I haven't seen done yet that is why I am trying to find the best way to do this. thanks guys this stuff is great. i also love the dash in that Merc.
  21. Ryan
    Ryan
    ADMINISTRATOR
    You can get em from Speed & Chrome, but mine is a real Bell that was done a long time ago...
  22. lockwoodkustoms
    lockwoodkustoms
    Thanks Ryan. I love that look
  23. Moonglow2
    Moonglow2
    I cut the web out of the dash bezel of my 54 Chevy and Muggy welded it and had it chromed. Then I used a brown 1/2 inch Cratex rod that I turned down to 3/8 in. dia. I used a piece of stainless to get more pop than aluminum. Pics attached
  24. 36C8
    36C8
