Just curious, who's flame thrower kits are the best? Not looking for 80 foot balls of fire (NO PROPANE!), just your normal everyday 1-4 foot firecracker. Looking for something that doesn't stall your motor and flood your cylinders gas either.
Contact spitfire. It took about 300 bux to finish the deal. Totally alternate fuel system, you can run whatever from alcohol to deisel. I use a MOON 5 gallon tank. Tons o fun.
Whoa dude, that's alot of fire. Maybe more than I'm needing. Are these Hotlicks Kits any good? It looks simple and easy to use....http://www.hotlicksexhaust.com/
that is the kind of kit that contaminates the oil . a safer way is to use an injected kit which gives a different style flame such as the one you see here
That Hotlicks Kit looks like the kind of system that doesn't momentarily stall out the motor and send gas through the cylinders. Looks like an active ignition system...am I wrong?
