Header Question
Discussion in 'The Hokey Ass Message Board' started by jbradleyd, Feb 6, 2008.
  1. jbradleyd
    jbradleyd
    Can I run with full length headers no exhaust. Someone said that it would warp the valves. Idk. I will eventually run mufflers, but I want to do that last (after undercoating and paint)
  2. Irish Dan
    Irish Dan
    After running your headers, you allow cooler air to flow up the tubes and into the ports on your heads. This process WILL warp your valves eventually. The greater the difference in temperature is, the worse the damage is. Another offering of my 2 cents only.
  3. jbradleyd
    jbradleyd
    Well im not gonna drive it much I just need to move it around in the shop to finish it. Then maby to the muffler shop. 5miles at the most do ya think it will be ok
  4. I think you'll be just fine with that amount of run time.
  5. FEDER
    FEDER
    You will be fine. Been doin it with My racecar for years and no valve damage.
  6. jbradleyd
    jbradleyd
    Cool........................ Thanks
  7. old dirt tracker
    old dirt tracker
    from phoenix
    same as feder, ran race cars 20yrs with open hedders and no problems. old tale like sitting a battery on concrete.
  8. BBCFUNNYCAR
    BBCFUNNYCAR
    If you think about it, full length headers is all that drag cars have and they don't suffer any negitive effects.....
  9. 1940AD
    1940AD
    from New Jersey
    does this 'theory' apply to short headers - like small zoomies or lake pipes?
  10. oilslinger53
    oilslinger53
    from covina CA
    except that they are constantly being rebuilt:) i think it mainlt short exhaust thatll cause this problem
  11. Don't worry about such silly things. I ran a motor with straight heads once. Man, they sure sound funny that way.
  12. jbradleyd
    jbradleyd
    Yea I guess I didnt look at it that way. duh If that were so every car with zoomies would need valves
  13. Mercmad
    Mercmad
    from Brisvegas
    a WARPED VALVE? can't say i've ever seen such a thing and i've lost count of the engines I've rebuilt .Seen plenty of burnt valves and busted ones but it was all down to operator abuse.
    Open exhausts causing warping? nah!!
  14. Ebbsspeed
    Ebbsspeed
    They do sound crazy with no manifolds at all, just eight exhaust ports barking. We ran an old SBC without exhaust manifolds for a very short time, but did buzz it up and down the street once. Hard to describe, but it's quite a funky popping sound.
  15. jbradleyd
    jbradleyd
    IF you can run with just heads I have nothing to worry bout
  16. Yes, and some cool blue and yellow flames licking the inner fenders!
  17. Ebbsspeed
    Ebbsspeed
    You can run 'em without exhaust manifolds, but it's definitely the most likely to cause any damage, if damage can be done by cooling too quickly. I wouldn't recommend it, just in case. The one we ran with no manifolds was pretty much a piece of crap to start with, so we weren't concerned if any damage was done. Frankly, if the car would have caught fire from those 8 torches under the hood it would have just been more fun. Young and stupid can be very entertaining sometimes......
  18. Yeah, I ran mine with straight heads cause I was 16. To think of it, I think I'll excuse a lot of what I've done in life to the fact that I was younger than I am now. That way, it'll work year after year. But seriously, just run your pipes and worry about something else that might actually happen.
  19. slammed1
    slammed1
    There is a vendor who sells stuff in Summit and Jegs who makes header collector inserts that are designed to be used with NO exhaust whatso ever
    The baffles are inserted into the collectors and a rivet or 2 hold them in place while allowing you to run open headered without having the loudness/noise.
    Im looking for a link.
    Car Chemistry is the name and I personally know the person/comapny who builds these.
    http://store.summitracing.com/partd...&part=CCI%2D3FI03L&N=700+115&autoview=sku
    Here are some Mustang Muffler replacements using the same inserts in a section of piping that totally replaces the muffler.
    http://store.summitracing.com/partdetail.asp?autofilter=1&part=CCI-IM50A25&N=700+115&autoview=sku
