I have a universal "GM style" disk-drum combination valve (includes a proportioning valve), like the one MP Brakes sells and I'm not sure about plumbing it. I know what goes where, but I'm not sure about the SIZE of the lines. One site (that I can't find now) said that all lines had to be 1/4", which seems too big. My brake cylinders and hoses are all 3/16". Can I use adapters and use 3/16 like everywhere else? Or do I need to use large lines to the valve, and adapters stepping it down to 3/16 after the valve? Yes, I have a 10# residual valve for the rear and a 2# residual valve for the front disks, in case you were going to ask. This is for my Econoline, if that matters.
flat-bill wouldnt larger lines reduce pressure? I know a roundy round catalog I have sells larger lines for this purpose.
