so-cal jimmy shine wiring harness HELP NEEDED
Discussion in 'The Hokey Ass Message Board' started by hotrod66, Feb 8, 2008.
  1. hotrod66
    hotrod66
    from france
    hi,
    I need help for wiring my harness...
    I have bought from SO-CAL the "hot rod wiring harness" developped by Jimmy Shine but I can't find the notice.
    I have called So-cal but they said they don't have any notice to suply!!??:mad:
    If someone have this for me...
    THANKS :D
  2. HOTRODPRIMER
    HOTRODPRIMER
    Are you looking for instructions?,,,,on how to wire the car? HRP
  3. hotrod66
    hotrod66
    from france
    I'm looking for the original notice/instruction, with all the wire numbers and codes, where it all goes :confused:
  4. glenn33
    glenn33
    from Browns, IL
    Bummer....Give me some basics on the harness, how many circuits, color code, wire markings, and maybe we can figure it out for you.
    Glenn
  5. 1950ChevySuburban
    1950ChevySuburban
    from Tucson AZ
    I would guess it's GM based color coding, but they may have misunderstood you if you asked for "notice", not knowing you meant "instuctions" ?
    Just a thought...
  6. HOTRODPRIMER
    HOTRODPRIMER
    Is this the kit you have?
    <TABLE style="BORDER-COLLAPSE: collapse" cellSpacing=0 cellPadding=2 width="100%" border=0><TBODY><TR><TD class=ProdDisplay1>SO-CAL Universal Hot Rod Wiring Harness </TD><TD class=ProdDisplay1 align=right></TD></TR><TR><TD width="100%" colSpan=2></TD></TR></TBODY></TABLE>
    <TABLE id=AutoNumber3 style="BORDER-COLLAPSE: collapse" height=43 cellSpacing=0 cellPadding=0 width="100%" border=0><TBODY><TR><TD class=ProdDisplay2 align=middle width="20%"></TD><TD class=ProdDisplay2 align=middle width="20%"></TD><TD class=ProdDisplay2 align=middle width="20%">Price </TD><TD class=ProdDisplay2 align=middle width="20%">Qty </TD><TD class=ProdDisplay2 align=middle width="20%"> </TD></TR><TR><TD vAlign=center align=middle width="20%" height=37></TD><TD vAlign=center align=middle width="20%" height=37></TD><TD vAlign=center align=middle width="20%" height=37><INPUT id=strRealPricePass451 type=hidden value=795>$795.00<INPUT id=ProdDisc451 type=hidden value=0 name=ProdDisc><INPUT id=strProdPrice type=hidden value=795.00 name=ProdPrice><INPUT id=discountPercentage type=hidden value=1> </TD><TD vAlign=center align=middle width="20%" height=37><INPUT id=Text1 style="FONT-SIZE: 8pt" size=2 value=1 name=intQty> </TD><TD vAlign=center align=middle width="20%" height=37><INPUT id=buyButton451 title="Add This Item To Your Cart" onclick="return validateMin(0);" type=image src="http://www.est1946.com/Themes/button_themes/site_theme4/buy.gif" border=0 name=btnAction>
    <TABLE id=Table2 style="BORDER-COLLAPSE: collapse" cellSpacing=0 cellPadding=2 width="100%" border=0><TBODY><TR><TD class=ProdDisplay2 width="100%">Detailed Description </TD></TR><TR><TD class=sitewidefonts width="100%">Developed by Jimmy Shine, SO-CAL’s own universal wiring harness saves an enormous amount of time on your project and it looks cool. This is a real harness that is braided in black cotton twill and highlighted with a red tracer. We use GPT wire that is covered in multicolored cotton braid and then plastic coated. This is the authentic look of the post-war era and can be used on most 1928-’34 Fords.
    <TABLE cellSpacing=0 cellPadding=0 width=500 align=center border=0><TBODY><TR><TD>[​IMG]</TD><TD>Color-coded and numbered wires </TD></TR><TR><TD width=34>[​IMG]</TD><TD width=466>For use with Hotronic fan relay</TD></TR><TR><TD>[​IMG]</TD><TD>Comes with all necessary terminal ends and instructions </TD></TR><TR><TD>[​IMG]</TD><TD>For use with Centech fuse panel</TD></TR><TR><TD>[​IMG]</TD><TD>For use with Hotronic turn signal box</TD><TR><TD>[​IMG]</TD><TD>Uses a hi-low headlight switch SO-CAL part #001-60757 or #001-60763</TD></TR><TR><TD vAlign=top>[​IMG]</TD><TD>Comes with provisions for dome light, license plate light, front and rear turn signals, 6-gauge instrument cluster and lights, horn, electric fuel pump, headlights, parking and taillights.
    It says it comes with the instructions,,,and for the price somebody at So Cal sould see to it you get them. HRP
    </TD></TR></TBODY></TABLE></TD></TR></TBODY></TABLE>​
  7. hotrod66
    hotrod66
    from france
    what do you need? photo? list? ...? :confused:
  8. hotrod66
    hotrod66
    from france
    yes it is this one
  9. hotrod66
    hotrod66
    from france
    yes I think so, but you know, I am french, and talking on the phone with them is not easy, and they say they don't have any notice in stock...
  10. retro54
    retro54
    from PA
    Someone from SoCal, or with connections with the company needs to help this guy out... seems obvious the language barrier is hampering things... heck for that price, maybe jimmy should personally dictate instructions :)
  11. Gusaroo
    Gusaroo
    Call them and tell them you need the instructions...for $795, the least they could do is email you a pdf. The counter jockey who answered your call probably had no idea what you were talking about.
  12. hotrod66
    hotrod66
    from france
    I have sent an e-mail to Jimmy shine yesterday, but I have no reply. Thanks for helping
  13. hotrod66
    hotrod66
    from france
    here is the answer from socal:
    " I will find out through my purchaser if we can locate the instructions for your harness kit."
  14. cball
    cball
    Hotrod66,
    Have you asked for the wiring instructions? If not, you need to, if your asking for a "notice" you are going to get the same answer, no, because they don't know what that means. Call them back and ask for the wiring instruction manual for the harness you purchased.
    Good luck.
  15. hotrod66
    hotrod66
    from france
    ok, I'll try this...
  16. rodknocker
    rodknocker
    Did you look to see if the individual wires are labeled? Maybe there isn't any instructions, you just go by the wire.Try to find out who the supplier of the harness is and deal with them directly.
  17. hotrod66
    hotrod66
    from france
    yes the wires are labeled with numbers and letters. It's like a painless one.
    But it's not a painless... I don't know the supplier.
    I just sent a new e-mail to socal asking the "instructions" for my harness, I will see the aswer...
  18. 53sled
    53sled
    from KCMO
    $795! dude, that's crazy! Someone could have bought the el cheapo, flown over, and helped put it in for that much.
  19. hotrod66
    hotrod66
    from france
    In fact it's a friend of mine who have this problem, but he doesn't speak english at all, so I try to help him.
    That sure very expensive when you see what you have in your hands, but he bought it...
  20. HOTRODPRIMER
    HOTRODPRIMER
    Maybe you were speaking to somebody at So Cal that don't speak English as well as you,,,,,I have had that problem with a company on the west coast. HRP
  21. hotrod66
    hotrod66
    from france
    the thing is that my friend has already visited socal when he came in US few years ago and bought a lot of parts for his car (frame, hood, windscreen, dashboard parts, etc...) so they know him but as everybody say here, for the money he has spent, he could have a little more aftermarket service.
  22. JOECOOL
    JOECOOL
    Yes it's a language barrier thing. In France when you say look at my nice plump tomato you are talking about your girlfriend. In the States that would mean something juicy that we eat.
    Wait ,I guess that is the same HUH?
    Never mind!
  23. KomptonKid
    KomptonKid
    We all run into that problem around here.
    As far as the instructions, if push comes to shove, SoCal headquarters are just a few miles from me in Pomona. I would imagine they could at least Xerox a copy for me and I could mail them overseas as necessary, but I would think they would offer to email a PDF of them.
  24. HotRodMicky
    HotRodMicky
    reminds me of my 1st visit 10 years ago to So-Cal when i walked in a gas station to ask for directions.......
    The guy at the counter only spoke spanish......this was in O.C. wtf....
    Thesedays nothing really suprises me anymore when I'm over there......
  25. AA/Fuel34fordpu
    AA/Fuel34fordpu
    Hotrod66 Good luck I hope every thing works out ok for you and your friend!
  26. alchemy
    alchemy
    Send a PM to JimA. He is a SoCal store owner and might have them in stock. He's an OK guy. ;)
  27. sko_ford
    sko_ford
    wow 795 for just a harness wow
  28. 41woodie
    41woodie
    This appears to be a language problem, and should be easily solved. BUT 800 bucks for a universal wiring harness is nuts. I paid 1/2 that for a Ron Francis, particular to the car with all sorts of accessory circuits. Seems like a ton for a wiring harness.
  29. Chad s
    Chad s
    How could this harness possibly be better than a Ron Frasncis kit which runs about $350. I thought Francis was an expensive product (but WELL worth every penny). Francis makes one hell of a nice wiring kit, $800 bucks seems a kind of steep.
    I had never wired a car before, and the Ron Francis instructiuons were the best set of instructions Ive ever had for any product, and everything worked right on the first try.
    Im not one that normally complains about prive for a high quality item, but for $800, you should get a set of full color hardbound instructions!
  30. butch27
    butch27
    And a Lap Dance!!
