aluminum hoods
Discussion in 'The Hokey Ass Message Board' started by tex34ford, Feb 8, 2008.
  1. tex34ford
    tex34ford
    I read the excellent HAMB tech article on making hood side panels. It answered all of my questions except that I want to use aluminum for my panels. Any suggestions on what gauge aluminum I should use? I will be mounting the panels with Dzus fasteners.
    Thanks.
  2. HemiRambler
    HemiRambler
  3. SUHRsc
    SUHRsc
    for hoods and hood sides i usually use 3003 H-14 .062 or .063 thick
    you could get away with .050 if you had to
    good luck
    Zach
  4. Zach is right on with his recommendation. That said, I found .062 to be pretty tough to bend for my hood top so I bought a 36"x48" sheet of .050 from Ron Covell (800-747-4631) or e-mail covell@cruzio.com . That info may be outdated now since that was in 2001.
    The .050 was a little easier to work with. Your mileage may vary. I've since become marginally more skilled and would use .062 on my next project.
    Charlie
  5. tex34ford
    tex34ford
    Thanks for the quick replys.
