I've read up and I think I'm ready to install
Discussion in 'The Hokey Ass Message Board' started by turboroadster, Feb 12, 2008.
  1. the gl*** in the dodge cab.
    54 dodge truck with split front windows and 3 rear, both rear side windows are curved. I have all the new rubber, none has a lock bead.
    I am going to have a squirt bottle with soapy water and some rope cord, I'm guessing small like a 1/4 type nylon rope from lowes.
    any other clues or wishes of un-broken gl*** you wish to heap upon me?.:D
  2. I send wishes of un-broken gl***.
  3. nexxussian
    nexxussian
    I also send wishes of Un-Broken gl***
  4. BigRedDude
    BigRedDude
    Good Luck with that Tim, save the curved gl*** until last, build your confidence and skills up with the flats and if you do break anything, I can probally get you some OEM replacements.
  5. 47bob
    47bob
    Resist the urge to pry with a screwdriver or any thing else. ......Bob
  6. ALindustrial
    ALindustrial
    good luck man... when i was ASE certified in window repair i never broke a single piece of gl***... but you are doing something daring, best of luck fella! *wishes of no broken gl****
  7. HOWDY! RedDude! long time no hear from.:D thanks for the offer, I hopes I wont be calling you for that:D
  8. rusty1
    rusty1
    ...instead of the rope, I've used a length of electrical wire like 14 or 16 guage , lube the pinch welds with dishsoap first, it really helps. You don't need a lot of soap , just run some around the pinch weld with a finger; the rubber should pull/slide rite over the pinchweld nicely.Good luck.
  9. ^^ pinchwelds?
    and are you saying put the rubber on the gl*** first then work the rubber to the truck frame?
    I was thinking it would be easier with the rubber on the truck and work the gl*** in the rubber.
    now that you mention it,
    I guess it would be safer to have the gl*** in the rubber protected and work the frame of the truck instead of the gl***.
    dizzamn! thanks :)
  10. chopped
    chopped
    I've got a chunk of nylon, kinda like a tongue depressor to help roll the rubber in.
