BANG, Clunk, Clunk......Uh Oh
Discussion in 'The Hokey Ass Message Board' started by flt-blk, Feb 23, 2008.
  1. flt-blk
    flt-blk
    from IL
    I am in the middle of a relocation and came home to get my house on the market, I timed the visit with the Decatur Swap meet.
    Cab drops me off at 9:00, by 10:30 Im getting coffee headed to the swap when BANG; Clunk Clunk and the Aquamino won't move. Luckily I have a Backup hot rod, so I drove the Model A to the swap
    I thought I lost the Clutch.
    Just pulled it apart and found pieces of spider gears. This is strike two for this rear end, Me and Outlaw put a 15" crack in the housing a couple months ago. Time to narrow that 9" in the shed..
  2. HOTRODSURFER
    HOTRODSURFER
    from HATBORO,PA
    thank goodness you have a back up hot rod!
  3. The Shocker
    The Shocker
    Join the broken rearend club.I trashed the whole rearend in my Falcon at the Thaw last night...
  4. mazdaslam
    mazdaslam
    That's pretty common for those old Chevy rears.My Brother has done that to 2 of them in his 58 wagon. Welcome to Pennsylvania by the way!
  5. Kerry
    Kerry
    Isn't it cool to have enough HP to break stuff??
  6. Ray Frey
    Ray Frey
    from Arizona
    Yea
    I had a 56 chevy years ago wasted rear 4 times les than a year
    Not good on the budget
    Explain to wife Realy it just broke
    I stayed Vintage Olds/Pontiac 3.0 street Hwy 4.88 Spool strip Play
    No more broke rearend
    Today time for a 9"
    Good luck
    Ray
  7. Dirty2
    Dirty2
    Man that sux..
  8. Tudor
    Tudor
    from GA
    damn son - yer hard on yer ****.
  9. Pontiacres Ranch
    Pontiacres Ranch
    I drove the 56 Pontiac today, roads were dry.....coast side of the gears sound like a rock crusher! Cant hurt it! Found a Hamber in Iowa with the center section I need! Figured a Celebratory Cruize to the Beer Store was in order! Before the Change out.....there will be film!
    ED
  10. That's what you get... talkin' on your cell, drag racin', bustin' **** up... :D
  11. I hae seen you drive.......I cannot for the life of me understand how it broke.........
  12. flt-blk
    flt-blk
    from IL
    Now I know what broke, I hope one of the swap meet stragglers has one tomorrow.
    I just need a center section to get the car on the transporter then I can build the 9" after I get everything moved to PA.
    Slip joint for the 2pc driveshaft is next, especially since I don't have a back up carrier bearing in the car.
    Plan B: weld the ****er up for a Getto locker.
  13. flt-blk
    flt-blk
    from IL
    How in the world did these rear ends hold up behind a 348 or 409???
    Or did they?
  14. rab71
    rab71
    Sorry about your car man but damn that thing looks sweet, even on jack stands.:D
  15. PORKCHOP76
    PORKCHOP76
    from iowa
    i did that before, sux...
  16. Evel
    Evel
    damm rat rods.
  17. scrape
    scrape
    i have one if you need it.... $50.00 here in sherman....
  18. flt-blk
    flt-blk
    from IL
    Check you PM's
    TZ
  19. Silent_Orchestra
    Silent_Orchestra
    from Omaha, NE
    Sweet!! I nuked the rear end in my truck this morning, I've got an OT '94 Chevy with an Olds 425, TH400, and a Chevy 12 bolt. I did a big no no, I was leaving the gas station, and nailed it out of the lot. I heard a similar clunk clunk bang noise. Man did I feel like a dumb***...But now I get to use the 9inch I've been wanting to!
  20. Ranunculous
    Ranunculous
    The "Aquamino" is a tasty looking machine.Hope it'll be on the mend soon.
    Did those 55-64 Posi rears come apart like that frequently? I have a 4:11 58' unit behind a stock 350/350 setup.
    It's done a few smokey burnouts and by no means been abused by me?
    It clunks like hell going around a 90 degree turn like Posi's do?
    I always thought the axles were to question?
    A friend has a later Camaro Posi 3:42 that'll replace it.
    Just wondering....
  21. Anderson
    Anderson
    Wow, thats weird. Why would it just break like that?
    Oh yeah.
  22. #1They didn't! #2 I have ridden with you..............that car has way more snort than most 409's!
  23. flt-blk
    flt-blk
    from IL
  24. metalman
    metalman
    They didn't, least not in my 348 59 Elky. If it wasn't the spiders it was broken main caps holding the carrier. At least pumpkins back then were cheap and easy in junkyards, with a little practice ya got good at changing them in no time!
  25. Muttley
    Muttley
    You arent a real man until you blow up at least one rear end.
  26. BLAKE
    BLAKE
    Damn you're cool, even when yer stuff is broke.
  27. Angry Frenchman
    Angry Frenchman
    try getting A posi unit. A 9" is just an easy way out.:D
  28. SUHRsc
    SUHRsc
    tough luck man!
    have a safe trip back up to PA
    Zach
  29. zbuickman
    zbuickman
    I feel your pain..... Ive done that before with the inclusion of the rear planet set in the ******..... I see absolutly NO signs of abuse to that rear from the pics:D but seriously after they wear some they become misaligned and bind causing the explosion discsovered. I litterally only takes going around a corner to take one out.:(sorry for the misfortune but get her back on the road damit:)
  30. flt-blk
    flt-blk
    from IL
    32 hours and I'm back on the road.
    Ran up to Sherman and S****e hooked me up with a 55 center section, although it really didn't want to come out of the housing.
    And to top it off it's a 3:70 which is better than my 3:36 :)
    Slapped it in and went for Chineese food about an hour ago.
    Thanks S****e and the others that PM'd me with offers.
    TZ
