cheap ass bomber type seat idea
Discussion in 'The Hokey Ass Message Board' started by SloNLo, Feb 26, 2008.
  1. SloNLo
    SloNLo
    from NZ
    ok so i was leaning on a 44 gallon drum today and had a thought
    with a little work you could turn one in to Two bomber style seats
    cut like so and roll the edge over some tube, add a pad or blanket for your backside and it could work out alright
    any thoughts
  2. BBYBMR
    BBYBMR
    Intesting. Do it, and show us pics.
  3. ig'nant
    ig'nant
    Fun idea, but I think it's always going to look like a cut-up 55 gal drum.
  4. Rootie Kazoootie
    Rootie Kazoootie
    from Colorado
    "Back in the day" (60s) that was a common lo-buck method of making seats for our lo-buck dirt track modifieds. Kinda floppy after their cut up and need some bracing. A real "bucket" seat for sure.
  5. gas pumper
    gas pumper
    Back in the 60's The dirt track modified guys made driver seats out of 15 gal, or 120 pound grease drums.
    The ones everyone uses for shop garbage cans.
    Rootie sure types fast!
  6. dirtbag_46
    dirtbag_46
    from ohio
    Seems like if you did it right and you were carefull you could get two from one drum
  7. rodknocker
    rodknocker
    There was the lower part of the shopping cart too, that was somewhat popular.
  8. Shifty Shifterton
    Shifty Shifterton
    Place the cuts right and one of the seats could even achieve perfect ******** alignment.
  9. rusty1
    rusty1
    ....I had that very thot awhile back, you'd have to lean the seat back to be comfy but that could be done with the brackets. Sure would be cheap bomber style seats.
  10. temper_mental
    temper_mental
    from Texas
    If you have a fat *** this will work great other wise it will look like you recycled a drum .I have my doubts on how it will look ..
    Good luck
  11. el chuco
    el chuco
    You could weld some 1/4" round bar along all of the cut edges to add rigidity and to kill the sharp edges. Here's a seat I pulled out of a '60s modified dirt tracker as an example (notice seat belt holes).
  12. stealthcruiser
    stealthcruiser
    Now there's a thinkin' man!:D
  13. HomemadeHardtop57
    HomemadeHardtop57
    Mine has rod bent and welded to the edge..added some strengh and took away the sharp edge....it worked nicely
      34.3 KB
  14. Hooligan36
    Hooligan36
    figured id bring back an old thread....
  15. That strategiclly placed barrel bung could make a very convenient drain on longtrips.
  16. Thank you for an idea so cool! I LIKE IT!
