sneed some 51 ford f-1 ideas
Discussion in 'The Hokey Ass Message Board' started by knucklehed, Feb 27, 2008.
  1. knucklehed
    knucklehed
    wondering if anyone had any pics of a chopped and or lowered 51 ford f-1 so i can get some different ideas and different perspectives
    and also the cheapest way to lower my pickup
  2. stragedy
    stragedy
    Start here.
    http://www.jalopyjournal.com/forum/showthread.php?t=118980
    Then go here..
    http://www.jalopyjournal.com/forum/showthread.php?t=76069
    Then here..
    http://www.jalopyjournal.com/forum/showthread.php?t=138866
    Should give you some ideas to start with.
    Hoof has one he's working on that he's channeled 6 inches, good way to lower with losing the suspension.
    Someone else on here is working on one with a Z'd frame (sorry lost the name)
    Old Beet and family have a couple with serious roof chops.
    Yet someone else has an altered dragster being built around the cab from one.
    I am working on one thats on a late model chasssis with all Ford running gear. Chopped and channeled.
    You could use a modded axle and put the rear axle over the springs / c notch etc.
    Poke around ! I am sure you'll find plenty more I've forgotten.
  3. JRRoberts
    JRRoberts
    from Madison WI
    Plymouth Volare front suspension, 302, Toploader, 9inch. It has chassis engineering rear suspension.
    its a '48 with '51 front sheet metal, but you get the idea.
  4. knucklehed
    knucklehed
    thanks for the replys i like the rustbucket look
  5. stragedy
    stragedy
    Why not post some pictures of your starting point in one of those pictures threads.
    May as well resurect an existing one...
  6. knucklehed
    knucklehed
    I'll put up pic in the next few days ,thinking about useing a stock axle with 4in drop spindles and lowering blocks and reversed leaf springs in the rear.the motor is going to be a 351 w ford motor .what kind of trans would be best thank for the info
  7. daveheld
    daveheld
  8. Mark in Japan
    Mark in Japan
    look through my posts from my profile ;)
  9. chopolds
    chopolds
    from howell, nj
    1. Kustom Painters
    My shop truck. Rescued it from being a "street Rod". Chopped 3 1/2". 327 Chevy, 4 speed, 12 bolt posi w/4.11's.
  10. HOT40ROD
    HOT40ROD
    from Easton, Pa
    Here a picture of my 1948 chopped cab.
  11. 52 Pickup
    52 Pickup
    from Oakley, CA
    My 52.
    76 Chrysler Cordoba torsion bar front on a Gibbon crossmember.
    Gibbon rear springs and hangers.
    Dropped it about 4".
  12. ALindustrial
    ALindustrial
    i like the looks of these... expecially the '48s the grills are pretty :D
  13. stragedy
    stragedy
    Theres not a single picture of a 48 grille on this thread yet, they're all 51/52's Do you mean the big teeth ? Thats a 51/52 . The earlier ones have the horizontal slat grille.
    Here is where I keep all my 48-52 pictures - I've been collecting a while.
    http://picasaweb.google.com/stragedy/48To52F1S
  14. knucklehed
    knucklehed
    that things fuggin sick
  15. hoof
    hoof
    I didn't chop my cab because I am chickenshit, but the more pics I see I like them with the cab left full height. I do like to see the "forehead" over the windshield removed though.
    Nothing easier than channeling 6" over the frame. So many things just fell into place it is like ole Henry intended for it to work.
    CHAZ
  16. stragedy
    stragedy
    Hoofs channel came out very nicely, get him to send you the pics if you're interested - really opened my eyes up to doing it. Of course I am only going three inches and I'm not on a stock frame, but it should be easy enough (fingers crossed)
    Hoof, I think they look best with a little chop, somewhere between two to thre and a half but not more - OldBeet and Kmembers trucks are the only ones I've seen with biggers chops that i still like. I think Oldbeets is 5 inches ?
    Hoof, mine has has the roof panel stretched at the same time the chop was done, I am still undecided if I like it more or less, but it's done now !
    Did you ever get your fender clearance issue sorted out ?
  17. knucklehed
    knucklehed
    hey i would like to see your pisc if you could send them to me i would appreciate it
  18. k-member
    k-member
    Wow, thanks man, we quartered them to keep that nice factory shape. I sure wish I would have channeled mine. Got me thinking if I did channel one, I would drop the cab onto the running boards which is about 4" and then relocate the core support 2" higher to lower the front sheet metal and then a guy would only have to pancake the hood 2" istead of 4". I think that would look pretty cool with a 4" chop.
  19. Chop it and drop it. Wees knows how to make them look good...
  20. Heres my 50
    Volare clip 5" chop, 4" chop of windshield to lose the "forehead"
    Crowned roof with 40 Merc skin
    3 and 1/2" channel
    and on and on
    I keep having more ideas so it will probably never be done
  21. stragedy
    stragedy
    Tony, I'd love to see some more pictures of your truck if you got some.
    If you don't want to post them you can email me them direct and I'll put them in my collection.
  22. hoof
    hoof
    I think that a lot of my clearance problem came from the tall stock tires and rims that I can't use anyway(disc brakes), and I had the nose down too far when I mocked it up. I think that once I get the doghouse sitting plumb with the cab I will have a little more clearance. I may have even had the cab sitting nose down on the frame a little making it even worse. Time will tell, I just might have to mess around with wheel choices until I get something that works.
    I am not getting much done on the truck right now because I just got a car to work on. When I started the truck there were three of us, now there are four of us, so I needed something with a back seat.
    CHAZ
  23. Durod
    Durod
    from DFW, Tx
    damn-nice!
