Steel Roof on '29 Sedan ???
Discussion in 'The Hokey Ass Message Board' started by JohnnyFast, Mar 2, 2008.
  1. I have a non-computer pal who's building a '29 Ford 2-door sedan. He wants a steel roof on it and is wondering what newer car roof tin he can use that will fit the '29's contours best.
    Anybody done this ?
    TIA !! :)
  2. igby
    igby
    i build the comp***, and caliber new cars, in illinois and the roof of one of these would look so cool on a sedan. the roofs even have ribs if you want them.:D:cool:
  3. pimpin paint
    pimpin paint
    from so cal
    Hey,
    In the past, the roof panels from big station wagons worked out
    well. Sadly, most of these have been crushed. Perhaps, a mini van
    roof panel, either with the ribs or without, if he dosen't want that
    "street rod" look would work out. The Camaro/Firechicken roof
    panels have been used on the ABomb coupes, but not large enough
    for a sedan.
    S****ey Devils C.C.
    "Meanwhile, back aboard The Tainted Pork"
  4. Ranunculous
    Ranunculous
    Late 90's Jeep Cherokee 4dr's have ribbed rooves that might work? They're plentiful and cheap to be had.
  5. Kruzer63
    Kruzer63
    I used a roof skin out of a late 70s Volare or Aspen wagon ( i think it was a 78) I wanted a smooth roof and tho it has ribs when you see it, they are just screwed to the roof, a few holes to fill but matches the roof contour increibly. If you were to make a template and set it on the wagon, it wont match, but when you cut it out it will lay perfectly on the sedan. I was skeptical at first but it couldnt have fit better. Must remember that it fits on backwards.
  6. bumpybigblok
    bumpybigblok
    from Midwest
    I used a section of a 68/69 tempest on a 30 cpe. that laid on real nice, but i'm not sure for sedan? worth a look. Also 68 Chevy P/u
    is a perfect fit backwards for 33-34 cpe. Take a look at Suburban
    for sedan???
  7. flamedabone
    flamedabone
    Mine is an 01 Mazda Millenia minivan. The ribs are a bit street rodderish, but with the flames, you don't really see em.
    -Abone.
  8. flamedabone
    flamedabone
    PS. Kruzer63..that's a *****n little Model A.
    -Abone.
  9. Unkl Ian
    Unkl Ian
    '80s Malibu wagon,without roof rack,fits.
    Has 5 ribs.
    Early 90s Volvo wagon roof is smooth.About the right size.
  10. flathead6
    flathead6
    We used the roof out of a chevy full size van on a 27 T. It had cool ribs that ran the full length. It did take a little modification to the front and back of the T roof to fit right.
  11. Glen
    Glen
    If you find the perfect top off of a late model, check with a local body shop before you spend time cutting one off at the junkyard. some of those skins are very inexpensive.....
  12. Corn Fed
    Corn Fed
    A good ten years ago my brother and I used a 68-72 Suburban roof in a '29 sedan. It had the perfect side to side curve but was a little flat front to back. We had to make a couple of slices in the sides to get it to lay flat without buckling. It was smooth with no ribs.
  13. 29 sedanman
    29 sedanman
    from Indy
    This roof is off of a 80 olds wagon. This would be the same roof from 78-81 or so Malibu, buick, or pontiac wagon.
  14. luckylou
    luckylou
    from canada
    i used a roof out of a late model s-10 blazer it fit really good with nice contuorh
  15. pistinbroke
    pistinbroke
    Mine was filled with a roof from a 95 Astro van. I cut it larger then needed, placed it over the sedan and traced the outline I needed from the inside. I even used the van bracing. Worked great!!!
