Need sources for Holley 94 linkage and kits
Discussion in 'The Hokey Ass Message Board' started by mtd, Mar 4, 2008.
  1. mtd
    mtd
    from FL
    Looking for the best sources for Holley 94 stuff:
    Need a progressive linkage, extended throttle shafts and a couple of rebuild kits. Also jet and power valve reccomendations for dual setup on almost stock (edmonds 2x2,mild cam, headers) Flathead. thanks
  2. strombergs97
    strombergs97
    I like Charlie Price at Vintage Speed.Com..He has it all..
    Duane.
  3. weemark
    weemark
    from scotland
    dont expect charlie price to come back quickly - hes not known for his speedy service.
  4. Carb-Otto
    Carb-Otto
    from FINkLAND
  5. 29Jay
    29Jay
    from Ft Worth
    I got the carb rebuild kits for mine at my local NAPA. About $35 each after taxes. Rebuilding them this week...
    jay
  6. 29Jay
    29Jay
    from Ft Worth
  7. spoons
    spoons
    from ohio
    ask ****ster27 here on the HAMB.........
  8. Paul2748
    Paul2748
    Jets - the 8BA's came with 51's. Check the ones in the carb now - if around this go with those. Power valves - again, 8BA's came with a 7.5. Try a 4.5 in both for a starter. I don't have an info on stock 94's other than the 8BA's.
    The accelerator pumps in most of the kits you buy today are not the correct ones. The correct ones are 2.60 inches. The ones usually supplied are about 2.39 inches, supposedly a Merc? pump. I get mine from a place called Ken's Carburetors. (igadore@sbcglobal.net) His kits are more expensive than Mac's, but they have the steel tip needle in them and the right accelerator pump. He also rebuilds carbs, supposedly very good but I do my own.
  9. IGOR
    IGOR
    There's a older guy in Spartanburg NC. His name is Rudolph Faltermeyer. He's the man with 94's, linkage and stuff. Sorry don't have the number.
  10. IGOR
    IGOR
    Sorry, that's Spartanburg, SC
  11. swimeasy
    swimeasy
    Somebody please post that guy's # ^^^^^^^ PLEASE, I need help to!
  12. slam49
    slam49
    from tulsa ok
    pm ****ster27, he's a super nice fella. should have anything you need
