Further Inpiration: Aircraft Panels
Discussion in 'The Hokey Ass Message Board' started by Ryan, Mar 7, 2008.
  1. Ryan
    Ryan
    ADMINISTRATOR
    kidcampbell71 likes this.
  2. Mark in Japan
    Mark in Japan
    More guages than a Honda drift car! :eek:
  3. Rand Man
    Rand Man
    Aviation was only about fifty years old in the era we consider traditional hot rodding. I think it's safe to say that anything aircraft was the "shizit" at the time. When you consider the advancements between the Wrights and the end of WWII, it was the ultimate in engineering. A bunch of dials on your dash would be very cool indeed.
  4. One of my uncles used to design instrument panels for McDonnel-Douglas from sometime in the 1950s till he retired in the 1980s.
    Sorry, I don't remember the models he worked on and I don't have the family history handy.
  5. devildog101
    devildog101
    My friend used to work for a surplus store & used a bunch of aircraft gages in his 68 chevy camaro. He made up his own dash. Looked pretty cool.
  6. Brad S.
    Brad S.
    I like when I see an "inspired" interior but I think that it's getting over done in some cases. I intend to pull the color and layout eventually but even that's pushing it.
    I like mine with a nice steering wheel, subdued ignition, and few gauges.
  7. 4tl8ford
    4tl8ford
    from Erie, Pa
    I entered the USAF in 1967 and was trained as a Recipacating Aircraft Mechanic. I was fortunate enough to get to work on the C-47 (DC-3), A-26, T-28, C-123, O-1 & the O-2.
    There were random vehicle searches for those leaving the Bases for Aircraft Equipment, the very items you pointed out.
    (And no, I have nothing for sale.)
  8. TOE
    TOE
    Ryan,
    Did you get to climb up/in to the planes to shoot those pics?
    That must have been pretty damn cool if you did.
  9. scootermcrad
    scootermcrad
  10. G V Gordon
    G V Gordon
    from Enid OK
    I think the two wheels shows promise. If I get tired my wife can drive without switching seats. lol
    I think a well thought out dash really CAN make a car. Very few of the aircraft "inspired" ones I have seen look well thought out though.
  11. blkcat77
    blkcat77
    The coolest thing about most planes is that they are almost all from the 50s era or at least their designs are. If you check out your local small plane airport you'll see all kinds of interesting dashes first hand and most likely find nice guys willing to let you check em out and probably want to explain every detail of how they work.
  12. Roothawg
    Roothawg
    The problem is that most a/c parts are 24v.
  13. 1950ChevySuburban
    1950ChevySuburban
    from Tucson AZ
    If you stare at them, the eyes boggle.......
    if you sit back and look casually, the symettry and design come into play. Thats the best part for me
  14. Digger_Dave
    Digger_Dave
    What "boggles" me is; HOW the HELL did the pilots (and co-pilots) remember what each of the switches, gauges and controls DID!!
    I have trouble keeping track of about FOUR!!! (in my truck)
    (probably explains why I never got my pilots license!) :D :D
  15. BOBBY FORD
    BOBBY FORD
    Have to admire anyone who could fly one of those things or should I say any two who could fly those things. LOL
  16. HOTRODSURFER
    HOTRODSURFER
    from HATBORO,PA
    wow that is a cool *** picture,that a lot of gauge to keep trck of,guess that why there is a copilot
  17. Steve Hedke
    Steve Hedke
    What we would do in a new plane is sit in the ****pit and memorize the layout. Often we'd close our eyes and reach for each control. Not only did we need to know where the were and be able to interpret the data, we'd have to know how they worked as well.
    For example: instruments are grouped in 3 sets. Flight data (comp***, tuen & bank, altimeter, vertical speed), engine data (tach, temps on oil and exhaust, pressures), and 'consumables' (fuel, oil, battery, etc.). Times however many engines you had. Those big radials would use more oil per hour than your hot rod could burn gas in a month.
    Then add radios to the mix, both communication and navigation. Usually there were two comm radios for a backup.
    You didn't use everything at once. But you learn to scan from flight instruments to engine, but mostly flight. Just like our cars, the engine readouts were used periodically, not constantly.
    Most planes group the flight instruments in the same way. The knobs are not only colored differently, they have different shapes. Landing gear feels like a tire. Prop has knobs around the outside. Engine power is mixture-prop-throttle. To add power, first richen, then change propeller pitch from cruise to climb, then add manifold pressure (throttle).
    Lots of old hot rodders filled their dashes with gauges. Not all are electric: altimeters work on pressure differential.
  18. Steve Hedke
    Steve Hedke
    The ****pit wasn't where all the gauges were. Try the flight engineer's station. Those big radials needed a separate crewman to handle them, especially on the 4 engined stuff like Connie's and Doug's. There's an instrument panel!
    If you mishandled those engines with their two speed superchargers you could blow one up real easy. Constellations often landed on 3 engines when one of the Wright 3350 turbo-coumpounds would pack it up. They had oscilloscopes so that you could check the firing of each plug while in flight. Each cylinder had two, and the Wright 3350's had 18 cylinders each. That's 144 spark plugs to check while in flight.
  19. Reverend Bow
    Reverend Bow
    from Yuma, AZ
    For military/civil Jet aircraft, true (actually 28V), but many of the small general Aviation aircraft are 12 V
  20. Reverend Bow
    Reverend Bow
    from Yuma, AZ
    Very True...
    747-300 Flight Engineer's Station
    Or the B-29
  21. Bluto
    Bluto
    I kindda like it simple with just a little walnut surround :)
    Ever flown over a field of clover?
  22. Brian W
    Brian W
    This is kind of like how Cl***ic Instruments took inspiration for their new Bomber Bezel Series. I like 'em! Aircraft dials are the ****!
  23. Ramblur
    Ramblur
    Looks like Manfred von Richthofen wasn't real fond of gauge panels.
    Strictly business here.
  24. I made these awhile ago. Didn't even realize they sell them. I like my ****py hand cut ones better...those others are too bulky.
  25. 3wLarry
    3wLarry
    from Owasso, Ok
    If anyone is interested, I've got a sizable collection of WWII Aircraft guages and panels and other ****pit items that were destined for the coupe till I got sidetracked...:rolleyes:...anyone need a seatback parachute? :)
  26. Bumpstick
    Bumpstick
    The "crown jewel" of aircraft IMO:D. The B17 Flying Fortess.
    Took these at the Palm Springs Air museum. -stick
    ****pit.
    Nose.
  27. Ramblur
    Ramblur
    +1 for the B-17, my fave too.
  28. RocketSled
    RocketSled
    Dad had a 50's Navion (oddly enough, this one: http://www.navion.org/dogplane1_small.jpg )
    And I recall it came with an oddball dashboard that he converted to what is now a modern, standard dash. At the same time, another Navion owner in our local club decided to modernise _his_ dash in a haphazard sorta way... That was about the time I learned tact.
  29. rstanberry
    rstanberry
    from terrell tx
    If anyone gets the chance to see the Confederate (now Commerative)Air Force show in Midland Tx. it is well worth the trip.I guarantee you'll be impressed by the old war birds and the newer craft. We got to climb up and look in the ****pit of a B-1. Impressive to say the least.
  30. dogtag
    dogtag
    Love the pix and the planes.
    Got to take a few pix while at Boeing flight test back in the late 60's and flew on the first 707 which was called the -80 and the first 747 which was designated RA001.
    We spent lot's of time over the desert down in Phoenix testing scale 747 inlets.
    Here's a few shots of us getting the engines to do compressor stalls over Tuscon. A real hoot in a plane that size.
    I was just an electronics puke but did finagle a half hour of right seat time.
    Dogtag
