65 Mustang radiator fit in a 29 grille shell
Discussion in 'The Hokey Ass Message Board' started by 29paul, Mar 6, 2008.
  1. 29paul
    29paul
    :confused: Does anyone know or have pictures of mustang radiator in Model A grille shell.
  2. The_Monster
    The_Monster
    Ive got a 65 mustang fastback out in the garage. you want measurements?
  3. lostn51
    lostn51
    from Tennessee
    a friend of mine did it in his and it looks good and fits well.
  4. bigjohnson
    bigjohnson
    I don't have any pics, But I have an earley model mustang radiator in my 29 shell, looks good to me;)
  5. 52 Pickup
    52 Pickup
    from Oakley, CA
    Have one installed in a sectioned 32 shell and it fits easily. Allows use of stock Mustang hoses on the small block Ford too.
  6. carbon guy
    carbon guy
    from indy
    I was thinking of doing the same thing with a 28 shell. I think someone here has mentioned this before, I don't know. I got sbc 350, $400-$700 is a lot of money to me for a purpose built rad, compaired to a $100 bucks or so. Check out Autozone web site, it gives you dimentions of the rads. Any body done this with a sbc?
  7. Chris
    Chris
    I belive Jim Sibly just put a mustang radiator behind one (may heva been 32 though). I honestly cannot remeber the grill, but it was early Ford, and it was a 65/66 Mustang V-8 radiator
  8. Leaky Pipes
    Leaky Pipes
    do a search. many threads on this topic.
  9. primed34
    primed34
    I've run a mid '60's some kind of Ford(station wagon,van?) radiator in my '34 Chevy coupe since '82. It came with the car. I've had it recored twice. It has a 2 and a quarter inch core. Always worked OK with a with a warmed up 283.
  10. Scott
    Scott
    30/31 for comparison
  11. Kramer
    Kramer
    Yep thats what they look like. I'm going to section my shell so it fits a little better in my T.
  12. The_Monster
    The_Monster
    Well, since this thread is still up, I'll give you the measurements I took off the 65.
    Core thickness: 2-1/4"
    Top thickness: 3-1/4"
    Width: 17-3/4"
    Height: 21"
    in/out hoses on p***enger side
    Rad. cap on top, drivers side
    Hope that helps
  13. dv8
    dv8
    It's been covered a ton on other threads, but here's a pic....
  14. tex34ford
    tex34ford
    I have used one in my '34 with a chopped grill shell for 16 years. I run a 355 SBC, flex fan,long water pump, no electric fan. Fans sits about 1" from the rad. The stock water outlets work after some juggling of hoses. Cooling with a full hood could get a little marginal on a hot Pittsburgh day so I installed a stock 64-65 Mustang fan shroud, looks OK, works better than nothing, cheap.
  15. chevrod
    chevrod
    from Finland
    What hoses you use with sbc with long waterpump and the mustang radiator:confused:
  16. tex34ford
    tex34ford
    Wish I could help with part #s. I formed my hose patterns from large diameter wire and searched through the hose rack at my nearest parts store until I found matches. Look at longer hoses with the right matching curves, they can be shortened as needed. Not a very scientific way to do it but it works. It also helps to have a friendly counter person.
  17. 29paul
    29paul
    Thanks for all the info guys.Going to go with 65 radiator instead of 550 dollar walker.
  18. scootermcrad
    scootermcrad
    I just ran across this thread...
    Those of you running the '65 Mustang radiator and flipping them over, do you have any pictures of how you actually mount your radiator? Did you have stock style tabs added to the radiator? What about grille shell tabs and support rod brackets and the likes? Could use some pics! I have to tackle this VERY soon and will be ordering the radiator probably next week, for that matter. Thanks!
  19. 29Jay
    29Jay
    from Ft Worth
    I happen to have a '68 mustang rad and a 30/31 rad shell uncut right now. it is clear how to cut to fit. no guess work involved.
    Scouter, I think us Mopar guys need a flip. if you find somthing out, lemme know. my water pump is driver's side. Ford is p***... Big loop...
  20. chaddilac
    chaddilac
    I used a 55 studebaker radiator support chopped down to fit the width of the shell, then mounted the headlights, shell and radiator to it. It's very solid, and I won't have to have those rods running to the firewall.
    Then I'll make a shroud that fits just inside the grill shell to cover up all the ugly looks of the backside.
  21. Rio Grande Valley Deuce
    Post some pics of the fab when you get a chance.
    Thanks, RGV
  22. bluestang67
    bluestang67
    The stock shroud on a 67 is very thin . I have one in the shed and the radiator i can get a pic of them placed together in a 31 shell from the engine side tommorrow If anyone is interested . This is a great idea may solve alot of cash savings in cooling with a better unit .
  23. scootermcrad
    scootermcrad
    I'm flipping mine over so it fits better in a 32 grille shelle. Then I'll have my local radiator shop move the inlet and outlets accordingly as well as put a 90-degree filler off the back so I don't have tricky filling.
    Looks like mounting should be pretty straight forward then. Cool!
    Thanks guys!
  24. 29Jay
    29Jay
    from Ft Worth
    I'm still in mock up, how spendy is it to have them swap stuff around? Is your Hemi the same as my Poly?
  25. Please show us pictures when thats done.
  26. scootermcrad
    scootermcrad
    Hmmm... not sure if the stock water pumps on a 331/354/392 are arranged the same as a later 318, but I'm guessing so.
    OH... shouldn't be too bad to move stuff around. Was talking to someone that said they paid like $90 or so. That's still very reasonable.
    Absolutely Chris! It will be soon actually. Just need to order
  27. 29Jay
    29Jay
    from Ft Worth
  28. scootermcrad
    scootermcrad
