tail light bulb help, needed...
Discussion in 'The Hokey Ass Message Board' started by flathead31coupe, Mar 10, 2008.
  1. flathead31coupe
    flathead31coupe
    from indpls, in
    whats the best way to get an old light bulb out of its socket? it has alot of hard green/white looking junk all around the base, i tried but it wont move, and i dont want to bust the bulb with my fingers....
  2. sho1off
    sho1off
    from Buffalo MN
    i usually end up busting the gl*** with a pliers then crush metal part in, grab with needle nose pliers push down and then ccw to get it out
  3. twistedtrbl
    twistedtrbl
    from michigan
    I am sure there will be other ways of doing this. As long as the car lights are off, I just break the bulb and use pliers on the base.
  4. jetmek
    jetmek
    try gloves. if it breaks pliers
  5. 325w
    325w
    Break the bulb. Knock all the sharp edges down. use the needle nose pliers. Turn it back and fort. Lift out. Clean socket with a small brush. You can get one at the Ace Hardware. Apply lite coat of thin grease and intsall the new buld.
  6. Flatman
    Flatman
    A little penetrating oil might help...
    Flatman
  7. cadillac dave
    cadillac dave
    have used a potato, after you break the bulb, push the potato on the broken bulb and push and turn.the rust penatrant first sounds good. cadillac dave
  8. deucemanab
    deucemanab
    If You Can Find A Small Can Of Contact Cleaner,this Should Do
    A Good Job. Deucemanab
