Custom badge Tech.
Discussion in 'The Hokey Ass Message Board' started by rustybucket, Mar 7, 2008.
  1. rustybucket
    rustybucket
    There was a post some time ago here on the HAMB that really perked my interest… the post was about acid etching at home.
    http://www.jalopyjournal.com/forum/showthread.php?t=136610
    In that post along with several examples of etched badges were links to an article that described the process in greater detail.
    http://www.gasenginemagazine.com/archive/0403/0403_feature1.html
    I recently completed a little project for Ryan and thought it would be nice to add a little something extra so I decided to make a custom br*** tag for it using info from the above articles. Ryan thought it would make a nice tech piece so below are the details.
    First, come up with a design. In my case I had a specific area I wanted the badge to go that dictated the shape so I traced the area including mounting holes and scanned that tracing so I could do the design in illustrator.
    Designs should be done in black and white. Areas that are white will eventually be eaten away and filled with paint and areas that are black will be bare metal… I did my design the way I wanted it to look in it’s finished state. When the design was completed I had to mirror the image and reverse the colors for the transfer process.
    Next is to transfer the design to the transfer paper. This process, which has its routs in custom circuit board design calls for the use of a special transfer paper called PNP blue. I ordered my paper from a company online. The paper is designed to be printed on a laser printer and comes in standard letter size 8/12 x 11. It’s a good idea to fill your page with as many designs as you can get on the page because chances are it will take a few transfers to get a good usable one. Determine what side of the paper your printer prints on and load the paper with the chalky blue side as the side to print and let her rip.
    Once printed, carefully cut out the designs. Next step is to prepare the bras to be etched. Cut out a corresponding piece of br*** slightly larger than the design you intend to etch. The surface to be etched should be thoroughly cleaned and free from grease or oil, which could hinder the etching process. The opposite side should be protected from the etchent solution. There are several options to protect the backside. The easiest is to cover the back with tape, I have used masking tape as well as clear packing tape, both work but etchant has a tendency to work its way in around the edges especially with the masking tape. If the design is smaller than the br*** its usually ok if there is a small compromise around the edges. A better way would be to apply a thin coat of paint to the back.
    Once the br*** has been prepared its time to actually transfer the design to the br***. Lay down a couple of paper towels and place the bras on top. Place the trimmed PNP on the br*** and tape it down to keep it from shifting. Add another layer of paper towels on top. The transfer process is done using heat. Smaller designs are easily transferred using an iron set on high. I have found that holding the iron down under pressure for about 25 or seconds followed by gently sliding the iron back and forth with light pressure for an additional 30 or so seconds works. At this point carefully take the hot br*** to the sink and run water over it to cool it down. When its cool peel the PNP back to expose the transfer. If there are small areas that didn’t transfer you can fill them using a little spray paint on the tip of a fine brush. If the transfer failed miserably clean the part using solvent and start over. This step is one of the most challenging parts of the process. It takes a little practice to get a good transfer, once you get the transfer process down the rest is easy.
    Once you have a good transfer, mask off the remaining bare areas with tape and create a little handle with a loop of tape. The etching part of the process is done using a chemical called ferric chloride. Ferric chloride can be found at radio shack under the guise of PCB etchant or is widely available on line. I have found that the etching process is greatly enhanced by the use of heat and agitation. I bought a couple of small gl*** cooking pans with snap on lids, which are convenient to both etch in and store the etching solution. Place the br*** in the gl*** container on the stove with the tape handle sticking up and fill it with enough etching solution to cover the br*** by a ¼ inch. I jerry-rigged a set up to keep the temperature from getting too hot. It may take some experimenting and creativity to keep the solution from burning. It’s probably obvious but care should be taken to prevent a fire and to regulate fumes. If you’re stove is off limits this process can be done cold but will take longer. I have found that to get a good deep etch its best to leave the part in the solution for at least an hour. Agitating as often as possible will help aid etching. I usually agitate the solution over the br*** by rocking the gl*** container or lifting and dropping the br*** by the tape handle. To check progress lift the br*** out of the solution. When it looks deep enough pull the part out and rinse it. Although ferric chloride wont burn your skin it will stain it and anything it comes in contact with…it will also eat / stain metal so it may not be advisable to do this process or rinse it in an area you care about.
    Once the part has finished etching and has been rinsed you can remove the tape and trim the br*** / drill any mounting holes. I usually design a border into the part that can be used as a cutting guide. When the badge has been trimmed coat the whole front side with paint. When the paint has dried use a sanding block with some fine wet dry paper and wet sand the raised surface leaving the paint in the recess.
    The resulting part is a nice shiny new custom badge. The applications for this are almost limitless. With a little practice, very nice and professional looking badges can be done at home with minimal investment.
  2. TagMan
    TagMan
    Clear and consise!
    Thanks for writing this up - I always wondered how that was done. Now, I gotta try it myself.
  3. Why did you have to go and show me how easy it is?
    Now I'm going to have to go and do it myself.:mad::D
  4. zman
    zman
    from Garner, NC
    wow, very nice... thanks I can use this tech...
  5. HomemadeHardtop57
    HomemadeHardtop57
    So..I will need to use a laser printer? Also, is there a store that has this paper in stock that I can just walk in and buy it without having to do an internet order. Very, very cool post.
    Thanks
    Jerry
    Homemadehardtop57
  6. ALindustrial
    ALindustrial
    awesome job man... that thing turned out beautiful!!!!
  7. tdoty
    tdoty
    Don't know if anyone in your area has the paper in stock, but a coper works as well as a laser printer.
    The PnP blue is great stuff. I've also done this with laser transparency film and a copier........it's just a little more labor intensive and challenging.
    Print your stuff on a quality inkjet and copy it, and you should be just fine.
    Tim D.
  8. the-rodster
    the-rodster
    That is so friggin cool.
    Rich
  9. CrkInsp
    CrkInsp
    from B.A. OK
    Great info. Very well done.
    P.S. Most office copiers are lasers.
  10. VonMoldy
    VonMoldy
    from UTARRGH!
    I was trying to find this stuff online at radioshack to see if I could pick it up local. I found this thoughhttp://www.radioshack.com/product/i...origkw=pcb+etch&kw=pcb+etch&parentPage=search
    looks to be the same idea but you draw out the stuff with a pen instead of a transfer. Would this work. It wouldnt be good for fine details but a quick and possibly ****py way of doing a similar thing.
    This is freakin dope! I think even my toilet will end up with a custom timing tag from the toilet ****pers timing ***ociation you know the TCTA!
  11. rustybucket
    rustybucket
    I haven’t tried using a marker but my guess would be the results would be poor. If you were to try and color a larger area with the marker I think there would be problems with getting good coverage. On slick nonabsorbent surfaces the solvent in markers actually activates the dried ink and pushes it around leaving thin spots. You might have better luck painting with a brush. Anything is worth a try though.
  12. Ryan
    Ryan
    ADMINISTRATOR
    As cool it is... wait till you see the finished product that Chris made for me. Much more to come once I get it all finished up...
  13. devildog101
    devildog101
    Wow. Something new for me to try Thanks
  14. scootermcrad
    scootermcrad
    Ahhh! That's neat!!
    Man this is a great tech week!!! :eek:
  15. converseandbowlingshirts
    from Eugene, OR
  16. Wow, that's very cool! That badge looks great! That's a real nice design you came up with!
    I remember making some circuit boards, that it speeds up the etch if you lightly drag a Q-tip over the areas you're etching once in a while. There's a slimy salt that forms on the surface as a by-product of the etching, and if you sort of sweep that slop away lightly with the Q-tip, the etch moves along faster. Taking the part out and rinsing it once in a while also speeds it up.
    It might keep it shiny longer if you spray the whole thing with clear lacquer or clear acrylic spray.
  17. Django
    Django
    from Chicago
    That's awesome!
    I was trying to make a data plate for the B-24, but I just couldn't get the image to transfer properly. :(
  18. KIRK!
    KIRK!
    I made my own too. I'll post some pics when I get home.
  19. Mr T body
    Mr T body
    Alliance Vendor
    from BHC AZ
    This is one of those threads that gets your brain working overtime. I have a plotter (cutter) that I use to produce vinyl decals and am wondering if vinyl will hold up to the ferric chloride. Hmmmm..... time to play :D
  20. RatBone
    RatBone
  21. LOWCAB
    LOWCAB
    from Houston
    He added more. I got a few things I want to try out.
  22. CRH
    CRH
    from Utah
    What a beautiful, professional AND cl***ic looking logo. Great Tech, great design, I'm impressed.
  23. sixinarow
    sixinarow
    from Fargo, ND
    I also have access to a vinyl cutter, let me know your results.
  24. VonMoldy
    VonMoldy
    from UTARRGH!
  25. duste01
    duste01
    Love the work and the finish, makes me feel like I can do something worthwhile too.
  26. Ace Brown
    Ace Brown
    from OH
    So if i wanted the background say black or red or any color i guess, should i just paint it? I saw that one link a guy made a badge for his Atlas lathe and it was red and black, as did empire 32's badges. This is awesome. i had been wondering how to go about making some "fake" timing tags. Awesome stuff. Thanks
    -ace
    edit: never mind, i just re-read the post and you did indeed paint it and sand off the excess. my mistake!
