Hi every body, my engine is a flathead Mercury 1CM 1952. i have found this 3 manual speed gearbox in a french swapmeet, which is for me a standard Ford 1953. she came from a Ford mainlane with a 6 cylinder I block. (so i must change the bellhousing show on the picture to find a flathead bellhousing). Some one can tell me if i have right with the type of gearbox and where find the name and information about it on the net? can i adapt a floor shifter on it? what flathead car bellhousing can i adapt (pictures are welcome) ? thanks in advance for your answer sincerelly JPhi
Wilcap's site shows some block and bellhousings for identifying scroll down a bit and you'll see some that look about right here's a link http://www.wilcap.com/flathead.html#FHID I don't recognize the transmission but it looks uncannily similar to the Cad Lasalle most any universal aftermarket three speed should be adaptable.
thanks for your answer; wildcap don't speak about 3 speed manual gearbox; they look some flathead 8BM or truck bellhousing but whith no details. same thingk with vanpeltsales and the ford technical sources (only a drawing of the gearbox is show: ***le 1949 - 1954). i will look tothe cad lasalle. thanks again have a nice day
It is not a Cad LaSalle. It is a stock 49 up to? Ford trans. You need a 49-53 Ford bell housing. The merc used an adapter ring and the old style trans. You need to have Bruce really nail it down.
ok for the 49 53 bellhousing, i see the part. about the gearbox, can i adapt a floor shifter? i have found on the net that the original mount is a column front shifter, but aftermarket parts dealers speak about floor shifter possibility on this vintage trans . thanks in advance to give me information about.
I would guess that with enough work you should be able to put a floor shifter on that transmission. Most all of the trans of the 60s had the sideloader (shifter) setup and many of the cars had floor shifters -- think Mustang. You have been looking for a trans for a while now, remind us what you are putting it in. Reason why I ask, I have a couple of car trans from flatheads. One is from a '48-'50 ford, the other from a '51+ Merc. The rear mount on the trans on the '51 is an inch or so different from the older one. I think both measure about 24" long from front face of the trans (where the bell bolts on) to the end of the tail stock. I will try to see if I have the mount measures on my computer somewhere -- the transmissions are out by the shed and still buried in snow so I can't remeasure them for a while. I don't know if the mounting location will matter, but it is something to think about.
