ive got a ford 390fe and im gonna redo the exaust system on it with simple old true dual and gl*** packs. my question is what diameter should i use? my brother says i should use three inch but i was thinkin 2.5"
All depends on what you are putting it in. Open cab, truck, car, sedan...2"-2.5" is fine. If you've got a closed cabin, you probably want more tuning volume so you don't get that DROOOOOOOAAAAAANNNNNN in your head going down the road. Then again, if you've got some teeth that need to be vibrated out, it might be fine!
its a closed cab pickup, i want it lound outside the truck, so i was thinkin of welding them in uder the bed.
