Rear brake rebuild question
Discussion in 'The Hokey Ass Message Board' started by gavin, Mar 17, 2008.
  1. gavin
    gavin
    from Sonoma
    I am putting a rear end from a 74' Maverick in my car. It's from a junkyard and didn't have any brake parts on it. I can't seem to find a diagram for the mighty Maverick rear brake ***embly. It's just a Ford 8", so can I use a diagram from any 70's Ford rear? I usually leave one side in tact and copy it for the other size, but I can't this time. Please don't make me look at Maverick/Comet sites to find the answer!!!!!
  2. gavin
    gavin
    from Sonoma
    Anyone know the answer to this one?
  3. Mudslinger
    Mudslinger
    All the drum brake ***emblies from the sixties on are about the same. Some of the parts are different but if all you need is a ref. It will work.
  4. Bear Metal Kustoms
    Bear Metal Kustoms
    Alliance Vendor
    If you call a decent parts house you can get the parts needed..
    shoes come as set.
    rear wheel cylinders each need left and right
    small parts kit. need two. they come with springs, cups bars, etc...
    Jason.
  5. Paul2748
    Paul2748
    If you want an illustration, go to the library and look in an old Motor's Manual. All Ford 8 inchers were all the same as far as brakes go, unless there were ones before self adjusters. The 9 inchers also looked about the same as the 8 inchers, so pretty much any illustration of a Ford set up will work.
  6. Paul2748
    Paul2748
    About the only part that will not come with the small parts is the cross bar for the emergency brake. You should be able to use them from any Ford 8 incher.
  7. gavin
    gavin
    from Sonoma
    Thanks a lot, that's exactly what I needed.
