Flathead Tech
Discussion in 'The Hokey Ass Message Board' started by Flatdog, Mar 4, 2008.
  1. Rand Man
    Rand Man
    These could be found all on the same block, right? They are all intakes, right? Which cylinders are long and which are short? I guess the inner two on each side are shorter?
  2. blown49
    blown49
    I think the concenses is all on the right side are shorter than all on the left side.
    Now Flatdog here's another vote to expand on your theory please. (If it take begging I'm not ashamed to beg. It is for a good cause:D)
  3. blown49
    blown49
    OK so I took some liberties with a couple of Flatdog's pics. First off I angled them closer to what they would be in the block; then I mirrored them to place them on the correct sides (I think) when viewed from the front. If I'm wrong Flatdog go ahead and rag on me cause I prolly deserve it.
    It looks to me like the top of the left valve guide has been shortened but not the right. Is this part of the answer to the puzzle?
    The drivers side (Left)
    The p***engers side (Right)
  4. Flatdog
    Flatdog
    49 You done good.The only reason the ports look difference in the pictures is top pic (long side) is stock port, Bottom pic is a modified port(short side) with cut down guide.
  5. blown49
    blown49
    Well master of flathead experience I thought you were suggesting the answer was there I just had to get my head clear to see it. Thanks for the test :D:rolleyes:
  6. Flatdog
    Flatdog
    There is a lot of info in those pics, study them.
  7. 4tl8ford
    4tl8ford
    from Erie, Pa
  8. nexxussian
    nexxussian
    Thanks Flatdog. Very informative and nice pics too; dang, musta been alotta work, didn't you do a thread on the cutting? Maybe I'm just nuts, more than normal.
  9. alchemy
    alchemy
    An (almost) oldie but a goodie. Treasure this one folks.
  10. hotrod1940
    hotrod1940
    An interesting read on this topic is an article by Barnie Navarro in the Tex Smith flathead book.
  11. Bruce Lancaster
    Bruce Lancaster
    Flatdog owned an actual Barney Navarro sketch of a port...pretty much just a couple of shaky lines scrawled on s**** paper during a conversation, beyond interpretation by anyone not at the actual conversation, but you can be ***ured that Flatdog and Barney shared the contents of quite a few brain cells...
    He had I think just tracked down and started conversation with Ed Bingelli, another flathead superguru, when he died.
    Flatdog and I had both, it turned out, had wanted to know Bingelli's port tech since roughly 1962, when we read a very cryptic article on the mods in an HRM article on his improbably fast flathead g***er. Flatdog's very experienced take was that Bingelli's Willys/Ford was a solid 2 seconds faster than science could explain...
  12. Flat Ernie
    Flat Ernie
    Tech Editor
    Digger Dave posted a pic of a similar napkin type drawing by Navarro talking about both ports & reliefs...
    I know Joe Abbin showed me a note pad full of notes from his last phone conversation with Flatdog...
    EDIT: Found Digger Dave's pic:
  13. hotrodA
    hotrodA
    Ernie, what is that dimension of the lip between the relief and the bore? Looks like 1/3", or is it 1/8" Thanks! Bill
  14. Bruce Lancaster
    Bruce Lancaster
    I think Flatfog posted a pic of his Navarro napkin...can anyone find that on here?
  15. blown49
    blown49
    Bruce I think this was that post but the pic is gone:
    Original Flatdog Post (Picture is gone) 1-8-04
    Post #14
    http://www.jalopyjournal.com/forum/showthread.php?t=7463&highlight=navarro;napkin
    First posting I saw that referenced that post was by Flat Ernie:
    Flat Ernie Post of 10-17-04
    Post #30
    http://www.jalopyjournal.com/forum/showthread.php?t=31987&highlight=navarro&page=2
  16. Bruce Lancaster
    Bruce Lancaster
    Flatdog implies that the pic shown IS his...I remember it as being much less clear than that...dunno if we're discussing 2 pictures or one, my memory is so leaky. Need a new head gsket...
  17. Flat Ernie
    Flat Ernie
    Tech Editor
    Bill - it's 1/8" and the port radius is 1-5/8"
    I'm pretty sure I got the above pic from Digger Dave (has anyone heard from him lately?) in an offline email exchange a couple years ago. But I guess it could've been from online here stolen from one of Flatdog's always informative posts...
  18. Mac1
    Mac1
    To: Bruce Lancaster,
    Would you happen to know the
    minimum distance between the water jackets in Flatdog's Intake port pictures?
    Thanks,
    Mac1
  19. flatoz
    flatoz
    Mac1
    best to ask Bruce, Flatdog p***ed away earlier this year. A real loss to the flathead world.
  20. Mac1
    Mac1
    So sorry to hear this.
    He was a BIG do'er. God speed Flatdog!
  21. Bruce Lancaster
    Bruce Lancaster
    "Would you happen to know the
    minimum distance between the water jackets in Flatdog's Intake port pictures"
    No...no details on those pics!
    But, thickness of port at top is the actual issue; I believe Flatdog and Barney considered lower belly area of posrt useless, to be left alone or filled.
  22. Mac1
    Mac1
    Thanks Bruce.
    For a good running street engine, I agree.
    Mac1
  23. Elmo Rodge
    Elmo Rodge
    Between which water jackets? Wayno
  24. Bruce Lancaster
    Bruce Lancaster
    I interpreted this as total diameter, actually, how much whole tunnel could be hogged?
  25. Mac1
    Mac1
    Bruce,
    You are correct.
    I had cut up early blocks to check port wall thickness, but not 1948-53 blocks.
    The later blocks have a larger/taller coolant p***age under the intake port floor.
    To speed up the porting, I used various size round metal washers tacked to 4" to 6" lengths of 1/8" welding rod with the free end looped into a 5/8"-3/4" circle.
    The washers will measure around turns and corners in the ports, inside calipers will not.
    The washer diameters varied by 1/16". Used as a go or no go gauge in the port.
    First thing before porting, I would always measure from the deck to the top of the intake port water jacket wall for core shift, if any. I would port the roof first, the floor would be second, then the side walls third and fourth.
    For RACING, the roof wall would end up .050"-.060" thick.
    For the later blocks, not really knowing the intake port wall thickness at the coolant p***age running under the port floor next to the valve guides, I used a 1-1/8" washer for the vertical distance when porting the port floor, when the washer JUST slipped through into the valve pocket, that was it
    If the port roof walls were down from the deck some what, or the water jacket walls were real rusty, then I would use a 1-1/32"to 1-1/16" washer for the vertical after porting the roof; See left bottom picture of the first set of Flatdog's port pictures.
    Thats why I ask the question regarding the outside over all distance between water jacket walls.
    Wondering just how close was too close to the lower coolant p***age when porting the port floor.
    Measuring the guides in the pictures against a stock guide measurement and trying to come up with a ratio (in the pictures) between guide dimension and the distance between water jackets was not too successful, the ratios were not consistent.
    Mac1
  26. Elmo Rodge
    Elmo Rodge
    OK Mac. I have an 8BA block section but not a slice through the port like in the photo. I'll try to get a dimension in the morning. Wayno
  27. Bruce Lancaster
    Bruce Lancaster
    I would worry about consistency here...that is a hell of a complicated casting area with lots of small pieces of molding sand wired into place during the casting. Someone posted a picture of the flathead casting forms here...foundryman's nightmare keeping all the bits in the right places.
  28. Elmo Rodge
    Elmo Rodge
    I haven't been able to take any actual measurements yet, but my calibrated finger calipers tell me that there isn't much over .080 or .100" wall thickness on the sides of the port. I'll try for better measurements later. I'm sick today. Wayno
  29. Elmo Rodge
    Elmo Rodge
    OK. I took some fairly crude measurements. On the one side I can get to we're looking at about .130". Over the top going through the hole it appears to be on the order of .250 or so. As Bruce has pointed out, possibilities of core shift abound so I wouldn't go nuts on removing material. Have you tried to scale the photos? Wayno
  30. Mac1
    Mac1
    Elmo
    A stock flathead guide OD is 1.03"
    I used second set picture Pict0101(small) for the guide OD to the OA distance between upper and lower water jackets for a ratio.
    In picture: water jackets distance = 1.1875" approx. Guide OD = 1.00" approx.
    !.1875"/ 1.00" = 1.1875 : 1 ratio.
    Distance between water jackets = 1.1875 ratio x 1.030" guide OD = 1.223" (use 1.200" approx for this port)
    Mucho additional Flathead Tech on this site: Midstate Antique Stock Car Club - Flat Tech.htm
    Mac1
