generator brackett that mounts to a flathead ford intake,?
Discussion in 'The Hokey Ass Message Board' started by flathead31coupe, Mar 20, 2008.
  1. flathead31coupe
    flathead31coupe
    from indpls, in
    i saw somewhere that there was a brackett that mounted to the intake bolts, to mount a gen/fan when their was no factory mount to the intake
  2. FritzJr
    FritzJr
    Only $7.00 in the 1951 catalog
  3. flathead31coupe
    flathead31coupe
    from indpls, in
    thanks i may be in the market for one....
  4. Bruce Lancaster
    Bruce Lancaster
    The commonest bolt-on flange was Weiand...it simply attached to the front 4 manifold bolts. I've seen simple fabricated plate equivalents--just a flat piece with a U cutout and four bolt holes set horizontally and a vertical plate to take the fan/generator mount.
    Manifolds with no flange were for '39-41 applications that had crank mounted fan and no need for anything other than the offset gen mount.
  5. Shaggy
    Shaggy
    from Sultan, WA
    I need one too, missed a Weiand one a while back
  6. flathead31coupe
    flathead31coupe
    from indpls, in
    iam going to make mine i think, i will get some pics....
  7. lowsquire
    lowsquire
    from Austin, TX
    Ive got to make one too..might do a run and sell them on here..will be a bit funkier than just a plate, will have gussets with gofast holes in em.Tig welded, will get the parts laser cut. anyone interested at sixty bucks?
  8. cleverlever
    cleverlever
    Has anyone ever considered utilizing a racemate charging system in the back of each water pump pulley and running a belt in a perfect triangle from crank to each water pump?
  9. BobbyD
    BobbyD
    from Belmont NC
    Check with side valve at the hot rod company on here, I thunk he has what your looking for.
  10. flathead31coupe
    flathead31coupe
    from indpls, in
    i found it vtgb_lg.jpg thanks...
  11. Bruce Lancaster
    Bruce Lancaster
    So...who has those now?? Only ones I have are ancient finds, and there are lots of bracketless manifolds around.
  12. banjorear
    banjorear
    I though Tardell had them in his catalog a while back. I could use one as well.
    Tim
  13. PunkAssGearhead88
    PunkAssGearhead88
    from So Cal
  14. Kilroy
    Kilroy
    from Orange, Ca
    The bracket in the pic says V-Tardel on it...
    Anybody know if he still makes them? They aren't in his online catalogue anymore...
  15. flathead31coupe
    flathead31coupe
    from indpls, in
    Bruce, i havent found one yet those are out of stock..... i just made one up tonight, will see how it works out...
  16. Timmy Z
    Timmy Z
    Found this thread and it looks like it just turned 3 years old. I would like to bring it back to life by asking "anyone with pics of this part and Generator mounted to your flattie running 2 or 3 carb set-up?
