Who makes the best rear end jig??
Discussion in 'The Hokey Ass Message Board' started by bestrada11, Mar 23, 2008.
  1. bestrada11
    bestrada11
    from new mex
    IS it mittler bros or chssis works?? they are both about the same price.... does anyone have an opinion??
  2. bestrada11
    bestrada11
    from new mex
    The ch***is works seems to be 2 shafts instead of one long one.. they screw into the carrier bearing plugs and go out ward... and the mittler bros seems to be one long shaft... this maybe seems better than two
  3. Wesley
    Wesley
    I like my Mittler setup. Mittler has great cutomer service too.
  4. Brickster
    Brickster
  5. defender chassis
    defender chassis
    from WV
    I have never used one of these so keep that in mind when gaging my opinion.
    That being said, I like the Alston piece. The reson is that the shaft end adapters screw onto the shaft. I reason that this places the face of the new housing end square to the shaft. With the other kits the adapter floats. This would allow the adpter to wobble on the shaft and the new housing end to wobble on the adapter. The shorter shaft does not scare me off because the relationship with the two housing ends do not matter as much with respect to each other as they do to the center section(I am sure my last thought is not going to come off clearly but not sure how to reword).
  6. 5window
    5window
    Tina Turner?? :) Sorry.
