Need help: 1950 Chevy 2sp Powerglide cooling lines
Discussion in 'The Hokey Ass Message Board' started by houtex63, Mar 24, 2008.
  1. houtex63
    houtex63
    from houston
    Need some help finding the ****** cooling lines. They were plugged up by previous owner and all we got at the shop is 3 speeds. Can anybody help identify where the lines go? I think I narrowed it down to these two. Thanks.
  2. wheredoldcarsr
    wheredoldcarsr
    I have a 50 all original give me a buzz next few days to remind me to check it out for you if you dont get any help thanks Rg 830-779-1700
  3. houtex63
    houtex63
    from houston
    thanks bro, i'll definitely give you a ring if i can't figure it out.
    does anybody else know? my next step is to unplug them both and see what happens.
  4. rdstr31
    rdstr31
    from Ney, OH
    Mine's lying on the garage floor so I'm looking at it from above! If you're looking at the ****** from underneath, they're at the rear on the p***enger side of the tailshaft, with the inlets facing toward the rear axle. The top one plugs into an "L" shaped fluid galley that dies into the bolt-on side cover.
    Hope this helps!
  5. houtex63
    houtex63
    from houston
    thanks rdstr31, i think that's the plug on the 1st pic. the second pic looks like it's got fluid all around it. kind of a dead give away i guess.
    been looking all over the net for a diagram, looking thru an old book at the shop and haven't come up with anything. just want to be sure before i spill that **** all over the floor
  6. stickylifter
    stickylifter
    from Detroit
    Check out the "Old Car manual Project" They have a shop manual up there that might show it.
  7. rdstr31
    rdstr31
    from Ney, OH
    Those plugs in the pics look like they go into the area around the vaccuum modulator (it's hard to tell from the pics). The line plugs are above and to the rear of the modulator, on the p***enger side up near the top, at the rear of the ****** facing the rear axle. They're about 3" apart, with the bottom one about 1" below and to the outside of the top one. The top one plugs into an L shaped galley. I'd take pics but I'm at work...:)
  8. ems customer service
    i have a good gennie 50 chev powerglide trans cooler call bob 216-541-4585
  9. JDHolmes
    JDHolmes
    from Spring TX
    What rdstr31 said. I just hooked mine up on a 53 Pontiac last weekend. Originally, they go to a special waterpump (Pontiac) or trans cooler. Some as part of the radiator. Mine has an add-on transcooler in front of the radiator.
